Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
Progress: Sway bars, Lowering Springs, DRAG Springs, Pivot bearings, and more
Old Apr 30, 2004 | 03:44 PM
ExospeedAMcrx's Avatar
Default Progress: Sway bars, Lowering Springs, DRAG Springs, Pivot bearings, and more
<u>Drag Springs</u>
Honda/Acura
Rear comes in pairs
1000lbs springs
900lbs springs
<u>Competition Bearings and Bushings</u>
Not for street use.
PM for pricing.
88-91 Civic/CRX Front Lower Control Pivots Bearings
88-91 Civic/CRX Front strut rod pivot bearings
92-95 Civic Front lower Control Pivots
88-95 Civic Rear Lower Control Pivots
88-00 Rear Trailing Arm bushings
88-95 Lower Shock mounts
for you hardcore road racers out there.
<u>Lowering Springs</u>
All $145/set
88-91 Civic/CRX 2" drop
88-91 Civic/CRX with B-Series swap 2" drop
92-95 Civic 2.3" drop
96-00 Civic 2" drop
92-00 Civic with H-series swap 2" drop
01+ Civic 2" drop
90-93 Integra 2.3" drop
94-00 Integra 2" drop
01+ RSX 1.5" drop
<u>Full Coilover sets</u>
Conact us for pricing.
<u>Alignment Kits</u>
Front and Rear camber kits $169.00
88-91 Civic/CRX
92-95 Civic
96-00 Civic
90-93 Integra
94-00 Integra
Front and rear camber kits $215.00
01+ Civic
02+ Civic Si
01+ RSX
<u>Front Anti-Roll Bar kit</u>
RSX 27mm $139.00
89-91 Civic/CRX 22mm $179.00
01-03 Civic 27mm $139.00d
<u>Rear Anti-Roll Bar kit</u>
$179.00 each for the rear sway bars
90-93 Integra 22mm
94-00 Integra 22mm
01+ RSX 22mm
92-95 Civic 22mm
96-00 Civic 22mm
More Detailed information on whats needed on the Bearings
Prices are retail for reference. PM me for special pricing.
<u>89-91 Civic/CRX</u>
1. Front lower control bearings $179.00
*inner part of LCA*
2. Front strut rod bearings $179.00 pair
*for crossmember rod*
3. Rear Lower bearings /Inner $179.00 pair
*inner*
4. Rear Lower bearings/Outer $179.00 pair
*outer*
5. Rear Trailing arm busings(polyurethane) $49.00 pair
6. Lower Shock mounts(polyurethane) F&R 79.00 set
*bushings on LCA where Shock mounts bolt to*
<u>92-95 Civic</u>
1. Front lower control bearings $179.00 pair
*inner part of LCA*
2. Rear Lower bearings /Inner $179.00 pair
*inner*
3. Rear Lower bearings/Outer $179.00 pair
*outer
4. Rear Trailing arm busings(polyurethane) $49.00 pair Special $35.00
5. Lower Shock mounts(polyurethane) F&R 79.00 set Special $59.00
<u>94-00 Integra</u>
*inner part of LCA*
*inner*
*outer
Modified by exospeedAMcrx at 11:52 PM 5/9/2004
Old Apr 30, 2004 | 10:38 PM
JinteDgraM's Avatar
Default Re: Progress: Sway bars, Lowering Springs, DRAG Springs, Pivot bearings, and more (exospeedAMcrx)
anti roll bar "kit"? for 90-93 does "kit" imply front and back includeD?
Old Apr 30, 2004 | 11:26 PM
Default Re: Progress: Sway bars, Lowering Springs, DRAG Springs, Pivot bearings, and more (JinteDgraM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JinteDgraM &raquo;</TD></TR><TR><TD CLASS="quote">anti roll bar "kit"? for 90-93 does "kit" imply front and back includeD?</TD></TR></TABLE>
for 90-93 Integra applications.. progress only has available the rear.
the listing shows rear and front separately.
Old May 2, 2004 | 12:37 AM
High RATE 1000lbs and 900lbs DRAG springs available for track use.
Old May 2, 2004 | 10:25 AM
krazie1's Avatar
BANNED
on 88-91 civic rear sway bar
does it connect to shock bolt or actually go on to the lca's
as I am search for something like st sway bars don't want the front
but since I go aluminum lca's can't bolt it there
Old May 2, 2004 | 06:11 PM
SuperSlow's Avatar
No love for prelude?
Old May 2, 2004 | 08:37 PM
delpoop!'s Avatar
Default Re: Progress: Sway bars, Lowering Springs, DRAG Springs, Pivot bearings, and more (SuperSlow)
for the sway bars is that 165 for front and rear and also what kind are they
Old May 3, 2004 | 02:12 AM
Default Re: Progress: Sway bars, Lowering Springs, DRAG Springs, Pivot bearings, and more (krazie1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delpoop! &raquo;</TD></TR><TR><TD CLASS="quote">for the sway bars is that 165 for front and rear and also what kind are they</TD></TR></TABLE>
the $165 price is for the rear sway bar only. these are PROGRESS AUTO brand.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">No love for prelude?</TD></TR></TABLE>
oh of course. just forgot to include it. I'll edit it soon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazie1 &raquo;</TD></TR><TR><TD CLASS="quote">on 88-91 civic rear sway bar
but since I go aluminum lca's can't bolt it there</TD></TR></TABLE>
the EF body bolts on to the rear LCA/
Old May 3, 2004 | 09:50 AM
lDanny's Avatar
pm'ed
Old May 3, 2004 | 06:58 PM
AF-b16a1's Avatar
Default Re: Progress: Sway bars, Lowering Springs, DRAG Springs, Pivot bearings, and more (DuMa)
goin to call you tommorow
Old May 4, 2004 | 01:45 AM
sounds good!
Old May 5, 2004 | 09:57 PM
the more interest, the better pricing gets.
Old May 6, 2004 | 05:47 PM
Eee Pee's Avatar
Default Re: (exospeedAMcrx)
Me showing interest in the bearings.
More of a reminder actually.
Old May 7, 2004 | 12:35 AM
taking orders already. the bearing sets should be done next week. Limited amount available so let us know if interested.
Wil
Old May 11, 2004 | 09:50 AM
bumjp
japerf1
Oct 5, 2010 01:34 PM
jdmrexx
May 29, 2009 09:23 PM
