rsx type-r motor
Old Apr 30, 2004 | 01:00 PM
sdpuck's Avatar
Default rsx type-r motor
Where can i get a rsx type-r motor from??
Old Apr 30, 2004 | 03:30 PM
dmotoguy's Avatar
Default Re: rsx type-r motor (sdpuck)
japan
check ebay, or do a search in the hybrid forum
Old Apr 30, 2004 | 04:42 PM
Kendall's Avatar
No such thing. You can get a DC5 Integra Type R engine from http://www.passwordjdm.com or http://www.hmotorsonline.com, or get ahold of K20EG and he'll help you out.
Old Apr 30, 2004 | 05:08 PM
H25's Avatar
H25
we have sold the k20 type R motors before. .. i can ship one to you if you want...
Old Apr 30, 2004 | 06:10 PM
sdpuck's Avatar
Default Re: rsx type-r motor (MHRacing-310)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MHRacing-310 &raquo;</TD></TR><TR><TD CLASS="quote">we have sold the k20 type R motors before. .. i can ship one to you if you want...</TD></TR></TABLE>
How much would it be and what are the specs
Old Apr 30, 2004 | 06:20 PM
Joseph Davis's Avatar
USDM RSX-S is the exact same engine with detuned cams, and there are also intake manifold changes between PRB and PRC castings - they look identical until you set them side by side.
I'm not at all up on K20 prices, but given what anything "R" commands in the B-series world I am going to advise you to get the USDM engine and save the money. Between bolt ons, Toda cams, and Hondata K-pro you'd have a very nice setup. K-series engines are very responsive.
Old Apr 30, 2004 | 07:18 PM
H25's Avatar
H25
its a jdm k20 type R it has 220hp 2.0 liter it comes with ecu. and it cost $5,700 palletized and shipped with insurance to rhode island..
Old Apr 30, 2004 | 07:20 PM
H25's Avatar
H25
Default Re: rsx type-r motor (J. Davis)
not exactly the same.. i would take a k20r over a us rsx type s anyday.. the tranny has a 4.7 final drive. and lsd.. the us doesnt even have lsd. and no 4.7 final. the head is pocket ported like all type R. the casting is different. the intake valves i think are different also, the manifold is bigger, valve springs are stiffer, it has more compression.. its actually more differences then simularties IMO.. hope this helps.. later
Old Apr 30, 2004 | 07:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MHRacing-310 &raquo;</TD></TR><TR><TD CLASS="quote">not exactly the same.. i would take a k20r over a us rsx type s anyday.. the tranny has a 4.7 final drive. and lsd.. the us doesnt even have lsd. and no 4.7 final. the head is pocket ported like all type R. the casting is different. the intake valves i think are different also, the manifold is bigger, valve springs are stiffer, it has more compression.. its actually more differences then simularties IMO.. hope this helps.. later
I don't know about the whole swap, as in transmission, but the complete long block assembly is identical save for the cams - same valves and springs. It's a roller cam setup and doesn't have all the oil being sprayed on the cams like the B-series - stiffer springs are a good way to **** RSX valvetrain.
But, that was what Doug @ Hondata told me, he's only had 2500+ K-series dyno pulls on CAT's DynaPack, he's probably wrong. **** you, Dougie, you tard! Making me look stupid!
Old Jun 2, 2004 | 11:18 AM
Slow_Em1's Avatar
Default Re: (Kendall)
hey kendall...did u swap the single cam out with the k20 yet?
Maddox
Sep 6, 2004 05:48 PM
nudo_typeR
Dec 2, 2003 01:41 AM
phantomCIVIC[99]
Apr 16, 2003 06:52 PM
madtypR
Mar 3, 2002 03:09 PM
StealthR
Oct 26, 2001 07:20 PM
