Easiest way to bump rev limit on 1994 obd1 ls ecu????
As the topic states, I am not to fimiliar on how this will work, but I need a few hundred more rpms while going through the traps...The stock rev limit is at 6900 rpm...I am looking to move it up to about 7200....Any suggestions??
you need to have a chip installed into your ECU with a higher rev-limiter.
you gonna want upgraded valve springs for this also. the LS springs are pretty soft and dont like anything more than 7200rpm.
dropd4door
Dec 29, 2004 09:29 AM
