Calling all Cali B18c ef's with skunk2 manifolds
Old Apr 30, 2004 | 12:45 PM
Rywire's Avatar
Default Calling all Cali B18c ef's with skunk2 manifolds (ref approval needed)
Hi, I have a b18c that is about to be dropped into my crx. I have noticed that it will be much easier if I used a manifold that sits the tb higher up. The Skunk2 was just announced carb certified for there gsr manifolds, and I was wondering if you think the skunk2 will fly with the refs. The manifold looks nothing like the gsr manifold, it remembles the type r one. But the fact that it is carb legal, makes me think that they cant give me crap for it. What do you think, thanks, Ryan
Old Apr 30, 2004 | 12:47 PM
APEX CRX's Avatar
Default Re: Calling all Cali B18c ef's with skunk2 manifolds (droppedcrxsi)
HEY just wondering are there any marks/stickers to distinguish thats its a Skunk2?
if there is, it should not matter now that its CARB certified right?
Old Apr 30, 2004 | 01:54 PM
APEX CRX's Avatar
Default Re: Calling all Cali B18c ef's with skunk2 manifolds (1)
um sorry but what does the ECU have to do with the Skunk manifold question?
But since we're on the ECU subject, as far as I know NO Ref will allow any ECU to be used other than the one corresponding to the motor
Old Apr 30, 2004 | 02:36 PM
PotatoePAPA's Avatar
Default Re: Calling all Cali B18c ef's with skunk2 manifolds (APEX CRX)
chipped ecu? The only reason the ecu would be an issue is if he kept the gsr manifold, because....no it wouldnt matter.
i dont know what to say
Old Apr 30, 2004 | 03:00 PM
spaceman's Avatar
there is no stickers or markings on my skunk2 mani,yes you can pass a smog ref if you have everything hooked up properly(vacum lines and stuff)
Old Apr 30, 2004 | 05:46 PM
Colin's Avatar
Skunk2's site says they are carb EO pending..... as long as the ref is following the rules he will require that the manifold is carb legal.
about the ecu.... the p72 should function fine on the skunk2 manifold. It won't throw a code in the absence of the IAB. It might not be optimum for performance, but if the ref is gonna get strict about things it should be able to at least let you pass the ref's inspection.
Old Apr 30, 2004 | 06:44 PM
xtrafastcivic's Avatar
Default Re: Calling all Cali B18c ef's with skunk2 manifolds (91IntegGS)
refs dont even check ecu's .... speak from knowledge not from your ***...
Old Apr 30, 2004 | 06:47 PM
spaceman's Avatar
Default Re: Calling all Cali B18c ef's with skunk2 manifolds (XtraFastCRX)
lol,ya dood i dont know what kind of refs some of you go to but the ones i find dont look for anything,they just run it..good luck anyways,everyone should pass eventually,may have to do some adjustments..
Old Apr 30, 2004 | 08:32 PM
Rywire's Avatar
Default Re: Calling all Cali B18c ef's with skunk2 manifolds (spaceman)
I called skunk today, and they said all the sensors on the gsr im fit on the skunk2. But I am still having a problem with this. If I have a different IM, wont the vac lines be in different places, and it wont match a gsr im vac diagram, and it dosent seem like I will pass.
Because I know when smogging a b16a gen 1, you have to run a U.S. obd1 IM, the jdm one wont work (different vac diagram/sensor locations). So, a skunk2 one seems like it would be the same type of deal.
Well, Im running a stock usdm p72 ecu. And skunk2 just got the carb approval for there gsr mani.
Some refs do check ecu codes... I know from people on this site telling me.
Well, ill call skunk again in the morning,
So does the IAB sensor bolt to the skunk im? Thanks, Ryan
Old May 1, 2004 | 07:27 AM
Wes V's Avatar
I've recently gotten my car together and it's pretty much what you are thinking about.
B18c, OBD1 conversion, P72a1 ECU, and Skunk2 intake in a 89 Civic Si hatchback.
The ECU doesn't know that the secondary intake tract is not there and does NOT throw any error codes!
I think that when I take it to the Referee, I'll bring the vacume diagram for an ITR, which is what the intake manifold is fashioned after.
Wes V
Old May 1, 2004 | 05:36 PM
Rywire's Avatar
Default Re: Calling all Cali B18c ef's with skunk2 manifolds (Wes V)
Wes, do u have a picture? What t-body are u using? What t-cable? do u have the black box (name escapes me...) under the IM hooked up? Thanks so much!! Ryan
PS, did u just call skunk and they sent the carb stuff?
Old May 1, 2004 | 05:39 PM
spaceman's Avatar
block box=pcv system i think thats what its called...
Old May 1, 2004 | 06:02 PM
Mr_CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">
PS, did u just call skunk and they sent the carb stuff? </TD></TR></TABLE>
I called skunk like 2 weeks ago because I heard the manifold was now CARB approved. I told them I needed to get a sticker for it, and after he asked which application it was for and my address, it was sitting in my mailbox about 3 days later.
Old May 1, 2004 | 06:17 PM
Rywire's Avatar
Default Re: Calling all Cali B18c ef's with skunk2 manifolds (Mr_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX &raquo;</TD></TR><TR><TD CLASS="quote">
I called skunk like 2 weeks ago because I heard the manifold was now CARB approved. I told them I needed to get a sticker for it, and after he asked which application it was for and my address, it was sitting in my mailbox about 3 days later.</TD></TR></TABLE>
Thats great!!. Ryan
Old May 1, 2004 | 06:18 PM
Rywire's Avatar
HAHA, look at our Avatars.... lol
Old May 1, 2004 | 09:57 PM
Mr_CRX's Avatar
haha thats funny. btw, nice site and car.. I'm planning on documenting the whole process of my swap too. Good luck with your BAR test!
Old May 1, 2004 | 10:34 PM
Rywire's Avatar
Gracias!! Ryan
Old May 2, 2004 | 02:48 AM
Fobtions's Avatar
jdm gsr with skunk manifold.
gsr throttle body with 90 integra throttle cable and ITR bracket. You must you use a different pulley on the throttle body , i used a 90 Integra one. You could use a d16 one but it makes the the throttle touchy as hell.
the black box is just for the IABs, the only other vacuums u need is the charcoal canister related items.
hth
Old May 2, 2004 | 08:07 AM
irev210's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XtraFastCRX &raquo;</TD></TR><TR><TD CLASS="quote">refs dont even check ecu's .... speak from knowledge not from your ***...</TD></TR></TABLE>
The ref in my area down in southern cali checks ecu.
Speaking from knowledge, not out of my ***.
Old May 2, 2004 | 08:10 AM
1's Avatar
Default Re: Calling all Cali B18c ef's with skunk2 manifolds (irev210)
Ya, Dan, I deleted my replies because of ignorant and isulting replies like his.
Old May 2, 2004 | 08:12 AM
Wes V's Avatar
Default Re: Calling all Cali B18c ef's with skunk2 manifolds (Fobtions)
droppedcrxsi;
You can see a complete write up on the Skunk2 at this link (please keep in mind that I tend to over-engineer everything!);
http://www.performanceforum.co....html
The complete index covering the build of my Honda is at;
If you have any questions, feel free to e-mail me at (and don't let the address scare you);
wesvn@chevelles.com
Old May 3, 2004 | 10:25 AM
frenchy's Avatar
holy crap - over engineer - you could say that, nice shots though with the motor bieng out of the car, lovin the hard pipes - if i could thread jack real quick, i have the same set up and i just run a longer hose to the pcv - is that just ghetto tech or does doing it the correct way have any advantages mechanically
Old May 3, 2004 | 10:29 AM
Rywire's Avatar
Default Re: Calling all Cali B18c ef's with skunk2 manifolds (frenchy)
frenchy,
Hey, that tranny do u have? gsr? What axles do u have? Thanks
Old May 3, 2004 | 10:33 AM
frenchy's Avatar
stock 94 integra
Old May 3, 2004 | 11:22 AM
Rywire's Avatar
Do they fit right, or are 89 teg shafts/ outers better? Thanks, Ryan
