Does the Greddy TDO4 kit fit on a B16?
I've got the greddy turbo kit for the 92-95 SOHC VTEC civic on my ZC and I'm thinking of upgrading to a B16 and I want to know if the Greddy manifold will bolt up on the B16?
Anybody know?
Anybody know?
Well the manifold won't bolt up since it's for a D16. You can have a manifold made, although a TD04 on a B16 won't really be such a big hit. I'd say sell it and buy a TD05-18G at least, then you can use a B-series GReddy manifold for the TD05.
You can get say an HKS turbo manifold for the b-series which will let you bolt up the greddy turbo. The greddy turbo will be pretty much instant spoolup, but it wont have much of a top end.
It will sorta feel like a stock eclipse..the boost just dies off at high rpm. My eclipse has a t25 (stock turbo..at least for now
) and i can hit 17psi at low rpm, but it falls down to like 9psi at 5000+ rpms. I would expect the greddy turbo and a b16a to be similer. Its sorta fun on the street...boost is almost instant.
liam
) and i can hit 17psi at low rpm, but it falls down to like 9psi at 5000+ rpms. I would expect the greddy turbo and a b16a to be similer. Its sorta fun on the street...boost is almost instant.liam
I was on some dudes site. He put that same kit on a LS(b-series) and ran a 12.8 @ 10PSI wid just bolt on **** like fuel and ignition, but stock bottom end, but then again an LS can handle that. For the manfifold he said u juss gotta modify the 2 outer bolts. Just take it to a shop and tell them u want it to fit a b-series. Good luck.
