MAP sensor???
I have a B16A2 '93 motor in my EG6, and now I have bought a ITR IM, and was wondering which map sensor to use??
I did not get the sensor with from the ITR, and my own doesn't fit. because it's mounted on the firewall)
Can I use a 3 bar map sensor (Boost app.) , I have only had luck to find theese cheaper than OEM Honda ,..
Maybe some one here has one they want to sel??
thanks..
thanks..
use the map on your firewall.. run a vac lin from the map to the intake manfold... OR extent the wires on the map sensor plug.. to plug into the map on the throttle body.. ... both will work..... if not boostest .. use a stock honda map
How would you plug the vac. line into the hole on the TB?? that can't be done with out an exstension on the hole?? I think that it sounds like much trouble, and some thing might breake..,
I dont think that it will work
Ill post pictures later..
Ok, here's the picture of the sensor i got..
And the sensor I need?? or could it be fixed??
This is the intake that it's going on..
The next problem is where do I connect this vac. line??
BUMP.. someone must have had the same problem.. I have searched, but nothing was mentioned about this..
The next problem is where do I connect this vac. line from the purge valve??
[/QUOTE]
[/QUOTE]
Yellow Dragon
Jul 23, 2003 02:01 PM
