Suggestions for properly replacing cracked A/C line?
Old Apr 30, 2004 | 08:26 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Suggestions for properly replacing cracked A/C line?
When I was installing my turbo kit last August, the jack slipped when I was lowering my car down and cracked my a/c line and bent it out of shape.
All the freon has leaked out and the system I'm assuming is pretty much empty. Now I know I need a new A/C line (actually both of them I think), but what I'm wondering is what is the proper method for replacing both of the lines and recharging the system? Is it pressurized? Meaning, should I make sure that air doesn't get into the A/C system? Is there any bleeding required when recharging.
Please help me, for I know nothing about A/C systems...except I want it to start working for this hot *** Minnesota summer coming up.
Old Apr 30, 2004 | 08:27 AM
Archidictus's Avatar
Unceasing Measure
A.) you need to replace the entire line
B.) yes it's a pressurized system and you need to get the kit or have it professionally refilled.
Old Apr 30, 2004 | 08:32 AM
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">A.) you need to replace the entire line
B.) yes it's a pressurized system and you need to get the kit or have it professionally refilled.</TD></TR></TABLE>
Thank you for the prompt reply. Is it hard to replace the lines? Are there any special clamps or hoses? I planned on buying the R-134A kit or whatever it is and recharging it myself. But I just wanted to confirm that it's a simple unbolt/bolt-up (then pressurize/recharge) affair?
Old Apr 30, 2004 | 08:34 AM
Unceasing Measure
Default Re: (boostincoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">Thank you for the prompt reply. Is it hard to replace the lines? Are there any special clamps or hoses? I planned on buying the R-134A kit or whatever it is and recharging it myself. But I just wanted to confirm that it's a simple unbolt/bolt-up (then pressurize/recharge) affair? </TD></TR></TABLE>
The difficult part, probably, will be getting the new line(s) in without kinking them. Aside from that, the installation shouldn't be too hard. The recharge kit comes with new fittings for the R134 systems and the recharge process itself is so easy a monkey could do it.
Good luck.
Old Apr 30, 2004 | 08:56 AM
cxSHOE's Avatar
Default Re: Suggestions for properly replacing cracked A/C line? (boostincoupe)
helms manual sent
Old Apr 30, 2004 | 10:01 AM
Default Re: Suggestions for properly replacing cracked A/C line? (cxSHOE)
******* sweet. Thanks to both of you for the help. H-T needs more direct, helpful posts like this.
civic95hbvtec
Apr 28, 2007 07:53 PM
aj99si
Apr 27, 2005 04:44 PM
FallenLordz
Jul 21, 2002 09:12 AM
auto-gs-king
Feb 28, 2002 01:21 AM
