Bad Boost Spike!
Yesterday I installed a Hallmans ES MBC and after i got it set to 9 psi, in 2nd gear it suddenly shot up to 15 psi. When i saw that i slammed on the brakes and stopped the gas and pulled over. Everything seemed to be fine, since the FMU had be covered, but thats now what im worried about. BTW this is on a base model rsx and not a type s, if that matters much.
Do you think anything in my head is damaged from this half second 15 psi? I think i would know if any major had happend the second i hit it.
Any insight is appreciated
Thanks...
Thanks...
It's call a boost surge. it happens when you speed shift or raising your rpm though the gears. Best solution buy a boost controller and blow of valve. wastegate alone sometimes isn't enough. I have the same problems on my 03 civic si on a greddy turbo set up.
singlecamslam98
Jan 14, 2007 09:38 PM
opto_isolator
Dec 13, 2004 08:53 AM
