Honda S2000 Honda S2000
Best deal on rear s02's?
Old Apr 29, 2004 | 11:13 PM
StinkyTofu's Avatar
Default Best deal on rear s02's?
I really hate the way my car slides around all over the place and i think it has something to do with the mismatching tires. That and the fact that my rear tires aren't even performance tires to begin with. Anyways, where is a good place to get the rear oem s02's mounted and balanced for a good price? Thanks.
edit: forgot to mention that i'm in socal. hehe oops!
Old Apr 30, 2004 | 01:52 AM
Civicboy's Avatar
Default Re: Best deal on rear s02's? (StinkyTofu)
You can only get OEM SO2s from the dealer, visit http://www.hardtopguy.com. He has the best deals on Honda OEM stuff.
Old Apr 30, 2004 | 05:09 AM
blacks2000's Avatar
Default Re: Best deal on rear s02's? (Civicboy)
Call Jim at the tire rack ext 364. He'll give you a good price and have them shipped to any service station you want. It's the cheapest way.
Old Apr 30, 2004 | 05:49 AM
Razor's Avatar
Default Re: Best deal on rear s02's? (blacks2000)
http://www.tirerack.com carries oem s02's. make sure you get the oem s2000 s02's, there are 3 different versions.
-the regular s02
-for porche
-for s2000
Old Apr 30, 2004 | 08:55 AM
Civicboy's Avatar
Default Re: Best deal on rear s02's? (Razor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Razor &raquo;</TD></TR><TR><TD CLASS="quote">http://www.tirerack.com carries oem s02's. make sure you get the oem s2000 s02's, there are 3 different versions.
-the regular s02
-for porche
-for s2000</TD></TR></TABLE>
Really!? News to me, thanks !
Old Apr 30, 2004 | 09:34 AM
OC 335i's Avatar
140s-150s is a good price.
Old Apr 30, 2004 | 10:20 AM
StinkyTofu's Avatar
Default Re: Best deal on rear s02's? (JMS JT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMS JT &raquo;</TD></TR><TR><TD CLASS="quote">140s-150s is a good price.</TD></TR></TABLE>
Just went to tirerack.com and found the rears to be priced at 162 each. Do you know where i can find them for 140-150? Thanks.
Old Apr 30, 2004 | 10:37 AM
Civicboy's Avatar
check out here&gt;&gt;&gt;
http://www.hondaautomotivepart...WHEEL
$118 for fronts
$128 for rears
Old Apr 30, 2004 | 11:14 AM
StinkyTofu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicboy &raquo;</TD></TR><TR><TD CLASS="quote">check out here&gt;&gt;&gt;
$118 for fronts
$128 for rears
NICE find Thank you very much for saving me a buttload of money.
Old Apr 30, 2004 | 11:18 AM
blacks2000's Avatar
Have you considered the SO3? I switched because i found the SO2 unreliable in the rain. Just a thought.
Old Apr 30, 2004 | 12:50 PM
jchung's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacks2000 &raquo;</TD></TR><TR><TD CLASS="quote">Have you considered the SO3? I switched because i found the SO2 unreliable in the rain. Just a thought.</TD></TR></TABLE>
sO3's are what im getting after im done w/ my stock sO2's.
Old Apr 30, 2004 | 06:17 PM
Civicboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StinkyTofu &raquo;</TD></TR><TR><TD CLASS="quote">
NICE find Thank you very much for saving me a buttload of money. </TD></TR></TABLE>'
You bet, you should e-mail hardtopguy at http://www.hardtopguy.com . He is from S2ki.com and is the cheapest I have seen on OEM items.
Old Apr 30, 2004 | 06:40 PM
StinkyTofu's Avatar
Yeah i really was considering them. However after searching up on the S03's on s2ki.com, it seems that the general consensus is that the S03 is only better than the S02 in terms of wet traction. Here in sunny southern california, wet roads are almost never a problem. I drive like a granny in the rain anyways.
Old Apr 30, 2004 | 06:43 PM
OC 335i's Avatar
I really like the Toyo T1S tire. I have those on my 17s. I do not know if they make an OEM replacement though.
p.s. The 225 rears is more like a 245 in a different brand.
Old May 1, 2004 | 04:47 AM
Marble's Avatar
p.s. The 225 rears is more like a 245 in a different brand.</TD></TR></TABLE>
Agreed...so if you ever change the model or brand of your tires...go one size bigger. Fronts up to 215, and rears up to 245. It has to do with the design of the tire for the OEM fitment on the S2K...Bridgestone made the contact patch "bigger" for the OEM S2K.
MAN!! $118/ $128 is a smoking deal! Thanks...in a couple of months I will be needing some new fronts.
Old May 3, 2004 | 07:38 AM
00MRSi's Avatar
$118 for fronts
$128 for rears
Good find.. Nice price..
Old May 3, 2004 | 06:28 PM
brian_k03's Avatar
those are some good prices
Old May 12, 2004 | 08:45 AM
ipoh's Avatar
Default Re: Best deal on rear s02's? (ATXS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATXS2K &raquo;</TD></TR><TR><TD CLASS="quote">
Will 245 be too wide for the stock rear wheels though? For most tires, we are probably really really close to the minimum wheel width "allowed".
Old May 12, 2004 | 10:36 AM
blacks2000's Avatar
Default Re: Best deal on rear s02's? (ipoh)
No, it will not be too wide. The stock 225 is actually closer to a 245 than 225.
Old May 12, 2004 | 10:49 AM
ipoh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacks2000 &raquo;</TD></TR><TR><TD CLASS="quote">No, it will not be too wide. The stock 225 is actually closer to a 245 than 225.</TD></TR></TABLE>
Sorry...what I meant to say was...will the tires be too wide for the stock wheel to handle?
I realize that the OEM 225 is almost like 245. Can the "narrow" stock wheels take the 245s safely? I would tend to think that at least an 8-8.5-inch wide wheel is better for 245-wide tires.
Old May 12, 2004 | 11:09 AM
blacks2000's Avatar
Yes they can take them safely. Beyond safely, it's recommended!!
Old May 13, 2004 | 07:54 AM
Marble's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ipoh &raquo;</TD></TR><TR><TD CLASS="quote">
I realize that the OEM 225 is almost like 245. Can the "narrow" stock wheels take the 245s safely? I would tend to think that at least an 8-8.5-inch wide wheel is better for 245-wide tires.</TD></TR></TABLE>
You will be fine. Hell my 03 GTI came with 245's stock on a 7" wheel. The rear wheel on the S2K is 7.5"...again yes, you will be fine.
Old May 14, 2004 | 10:04 AM
StinkyTofu's Avatar
A little update...I placed my order for rear s02's from http://www.hondaautomotive.com . Apparently the price listed online is the incorrect price. I just got off the phone with them a few moments ago and the actual price is 225 each and they're special order.
I'm gonna give hardtopguy.com a try now. Whats a man gotta do to get some tires for a good price?!
Old May 14, 2004 | 10:28 AM
blacks2000's Avatar
Tire rack mang. They're like 160 or something.
Old May 14, 2004 | 10:38 AM
StinkyTofu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacks2000 &raquo;</TD></TR><TR><TD CLASS="quote">Tire rack mang. They're like 160 or something. </TD></TR></TABLE>
Yeah i saw them for 169 there. I was hoping to find them in the 140-150 range though. I guess if worst comes to worst, i'll get them from tirerack. Thanks for looking out though.
