oil pressure...HELP!!!!
Old Apr 29, 2004 | 08:14 PM
turbofodo's Avatar
Default oil pressure...HELP!!!!
my friend has a 94 integra LS vtec 12:1 compression, b16a2 head....
the problem is that the oil pressure is only 55psi at redline....NO LEAKS...excellent compression....the headgasket is great... freshly built... I am thinking that there has to be an internal leak in the head that is draining back into the oil pan...im not exactly sure.
any help would be greatly appreciated
ben
Old Apr 29, 2004 | 11:26 PM
turbofodo's Avatar
Default Re: oil pressure...HELP!!!! (turbofodo)
Bizzump
Old Apr 30, 2004 | 03:18 PM
turbofodo's Avatar
seriously people...what is the deal with this car?
Old Apr 30, 2004 | 03:59 PM
quikrpm'z's Avatar
did you tee it off from the block or near the firewall? also what brand gauge?
Old Apr 30, 2004 | 04:06 PM
jdmotorsports's Avatar
if its consistantly 55psi and no leaks then who cares? mine is around 75psi under load.
Old Apr 30, 2004 | 04:24 PM
quikrpm'z's Avatar
Default Re: oil pressure...HELP!!!! (jdmotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">if its consistantly 55psi and no leaks then who cares? mine is around 75psi under load. </TD></TR></TABLE>
because its not reasuring to see the gauge at 55 instead of 75-80.
btw i have the same problem, my gauge stays at 50psi max
Old Apr 30, 2004 | 06:21 PM
Default Re: oil pressure...HELP!!!! (quikrpm'z)
well if i remember correctly stock oil pressure is supposed to be around 50psi@3000rpm. the whole point of a oil preasure guage is to warn you of a problem. if its always 50psi then great, its the day you see it go to 20psi and stay there.
Old Apr 30, 2004 | 06:39 PM
JDMorgan's Avatar
what oil pump gear, water pump and timing belt are you using?
Old Apr 30, 2004 | 08:48 PM
SwifterThanU's Avatar
Its my car thats having the problem. Its an ITR oil pump and ITR water pump. The thing is that it was at 75 to 80 at load. It is an autometer electric gauge. Come on guys i need help.
Old May 1, 2004 | 03:28 AM
Sack Master's Avatar
Default Re: oil pressure...HELP!!!! (SwifterThanU)
Well if it was a fresh engine then oil pressure will always be higher. When the engine starts breaking in and when the oil starts breaking down, it will have lower pressure. I don't think 55 psi is anything to worry about. If you think so then maybe replace the oil pump or start tearing down the engine to see whats up. Or maybe your oil pressure guage isn't reading right. I kind of doubt that though.
Old May 1, 2004 | 06:44 AM
WhiteTegSE's Avatar
Default Re: oil pressure...HELP!!!! (Sack Master)
i just got mine put back together and im showing 85-90 at 3000 rpm... id start lookin into that... Did u get a used ITR pump or a brand new one? If you got a used one mabye the gear is worn... You can take it apart and check the specs on it... I reused my stock B18B1 oil pump with 147.000 miles and im still pullin mad oil pressure...
Old May 1, 2004 | 08:35 AM
TwoKSiR's Avatar
The motor itself has about 3,000 on it. I got the pump ne when I forst did the LS/VTEC about a year ago, since than it has been rebuilt, new rings, bearings, and gaskets. The tranny blew about 2 months ago so while he was waiting to get the new one he pulled the head to get P&P, and added my old GSR cams. Im wondering if he didnt partially block one of the lines with teflon tape or something to the gauge.
Old May 1, 2004 | 03:04 PM
Default Re: oil pressure...HELP!!!! (TwoKSiR)
if a line is blocked the the preasure will be higher. i still think its ok. its under load that the preasure should be up. redlineing it in nuetral might not raise the preasure.
Old May 1, 2004 | 03:43 PM
J337_UNIT's Avatar
at idle im reading around 15 psi .. cruising i read around 50-60 .. gettin on it .. well i havent gotten on it yet but ive seen my pressure go up to near 90.. so 55 is alittle low if hes gettin on it IMO
Old May 1, 2004 | 04:00 PM
Default Re: oil pressure...HELP!!!! (J337_UNIT)
thats how mine behaves. cruising its around 60psi. wot it shoots up to 75.
Old May 1, 2004 | 05:26 PM
TwoKSiR's Avatar
At full throttle, under load it wont go over 55 psi.
Old May 2, 2004 | 07:20 AM
90turboteg's Avatar
oil pressure reads off of you main bearings, i would probably hook up a hand held oil press. gauge see what it reads, maybe change to a thicker oil, or check the relief spring in the pump housing for dirt or metal, cheap oil filter can cause low pressure, you should be showing 70-75 psi on a newly built engine (under load 4500 rpm and up)
Old May 2, 2004 | 06:08 PM
Default Re: oil pressure...HELP!!!! (90turboteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90turboteg &raquo;</TD></TR><TR><TD CLASS="quote">oil pressure reads off of you main bearings, i would probably hook up a hand held oil press. gauge see what it reads, maybe change to a thicker oil, or check the relief spring in the pump housing for dirt or metal, cheap oil filter can cause low pressure, you should be showing 70-75 psi on a newly built engine (under load 4500 rpm and up)</TD></TR></TABLE>
huh? "reads off you main bearings" wtf are you talking about? do you know how a engine builds oil preasure?
Old May 4, 2004 | 07:15 PM
turbofodo's Avatar
the problem has been fixed...it was actually a problem with the guage itself....
hondaz6lx
10
Jan 13, 2007 10:43 AM
racingant
16
Jan 23, 2005 10:16 PM
Teknic73
Jan 12, 2004 12:52 AM
RCautoworks
Jul 3, 2003 06:52 AM
RCautoworks
Jul 2, 2003 04:44 AM
