Anyone tried no radiator??
Old Apr 29, 2004 | 07:40 PM
Robb's Avatar
Default Anyone tried no radiator??
Anyone on here have any personal expierences running a meth car with no radiator. I have a hard time even getting the car to temp for a run, and thought this might be an option.
Old Apr 29, 2004 | 07:41 PM
99blackcivicSi's Avatar
Default Re: Anyone tried no radiator?? (Robb)
I know for a FACT that mark brauning dosn't run one they just run coolant in the block to keep things cirulating.
Old Apr 29, 2004 | 07:46 PM
bambooluv's Avatar
Default Re: Anyone tried no radiator?? (99blackcivicSi)
also bryan's car is radiator-less keep in mind both cars run on meth.
And so is bruanings.
Old Apr 29, 2004 | 07:53 PM
Reddog's Avatar
What about all motor on gas?
Robb's Avatar
Default Re: (Reddog)
thanks guys that solves that, no more radiator for me.
Old Apr 29, 2004 | 08:02 PM
A train's Avatar
was thinking about the same thing both our cars run on meth. i think its a good idea!!!
Old Apr 29, 2004 | 09:46 PM
dmotoguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reddog &raquo;</TD></TR><TR><TD CLASS="quote">What about all motor on gas?</TD></TR></TABLE> you;re gonna want to run a radiator
Old Apr 29, 2004 | 09:56 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: (dmotoguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmotoguy &raquo;</TD></TR><TR><TD CLASS="quote"> you;re gonna want to run a radiator</TD></TR></TABLE>
Why? I know of an all motor car from NJ that runs on gas and doesnt use a radiator, The car is only running for a whopping 20 seconds at a time..
Old Apr 29, 2004 | 10:02 PM
Default Re: (SIXTYdashONE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTYdashONE &raquo;</TD></TR><TR><TD CLASS="quote">
Why? I know of an all motor car from NJ that runs on gas and doesnt use a radiator, The car is only running for a whopping 20 seconds at a time..</TD></TR></TABLE>
I would feel much safer running no radiator w/ meth than no radiator w/ gas, since meth has teh cooling charictoristics gas dosn't
Old Apr 29, 2004 | 10:16 PM
HT's Biggest Loser
Default Re: (99blackcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">
I would feel much safer running no radiator w/ meth than no radiator w/ gas, since meth has teh cooling charictoristics gas dosn't</TD></TR></TABLE>
<FONT SIZE="7">DUH</FONT>
Old Apr 29, 2004 | 10:18 PM
<FONT SIZE="7">DUH</FONT></TD></TR></TABLE>
wtf was that for?????
Old Apr 29, 2004 | 10:35 PM
HT's Biggest Loser
BEcause mostly everyone knows that meth has a better cooling effect., but that doesnt mean that there are mother**ckers out there that dont use gas + no radiator
Old Apr 29, 2004 | 10:38 PM
did i say there wasn't no i didn't. i stated a fact that not EVERYONE knows, no need to jump up in my **** like that for saying something that is true.
Old Apr 30, 2004 | 05:21 AM
Scott Mohler's Avatar
I haven't ran a radiator for over 2 years. No problems. Darrell fills our blocks with Hard-Bloc which actually helps dissipate some of the heat. We run methanol now, but ran it this way on gas also.
Scott
Old Apr 30, 2004 | 05:34 AM
trbobldr's Avatar
Default Re: Anyone tried no radiator?? (Scott Mohler)
Have you ever had a problem with the hard-bloc cracking or separating?
Old Apr 30, 2004 | 07:17 AM
Default Re: Anyone tried no radiator?? (trbobldr)
It cracked/separated one time only on the head, block afaik has been fine.
Old Apr 30, 2004 | 08:37 AM
adrenalinjunkie's Avatar
We run methonal and no radiator.
Old Apr 30, 2004 | 09:00 AM
Lei Siew Long's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">did i say there wasn't no i didn't. i stated a fact that not EVERYONE knows, no need to jump up in my **** like that for saying something that is true.</TD></TR></TABLE>
don't worry about him. he thinks he is the know it all of all know it alls
Old Apr 30, 2004 | 12:32 PM
1fstcorrado's Avatar
Scott you say you guys fill your head and blocks no water or cooling at all? just curious.
Old Apr 30, 2004 | 01:44 PM
H25's Avatar
H25
go for it.. btw nice looking car rob.. it looks like a full race version of my street car.
Old Apr 30, 2004 | 04:18 PM
ringgold's Avatar
Default Re: Anyone tried no radiator?? (MHRacing-310)
I know Darrell *** from along time ago and I know that he used to fill the block up make it solid and then just run coolant through the head of the car. He did that on Brent Rau's engine and he did that on his old setup on the green Neon that he used to run.
Old Apr 30, 2004 | 05:22 PM
turbo96wr's Avatar
no radiator is fine but you must run a catch can because there will be pressure created by the water or coolant or evian waterless coolant from the heat if you are going to dyno or during the run alway's let out pressure after the run.
Old Apr 30, 2004 | 05:27 PM
ringgold's Avatar
Default Re: Anyone tried no radiator?? (turbo96wr)
NHRA Pro Stock Bikes dont use radiators and they have to run race gas. The have vaccuum pumps on them to suck out some engine pressure also.
Old Apr 30, 2004 | 05:34 PM
Robb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo96wr &raquo;</TD></TR><TR><TD CLASS="quote">no radiator is fine but you must run a catch can because there will be pressure created by the water or coolant or evian waterless coolant from the heat if you are going to dyno or during the run alway's let out pressure after the run.</TD></TR></TABLE>
Thanks for all the responses from everyone.
How do you plumb in a catch can on a radiatorless system?
Old Apr 30, 2004 | 05:37 PM
turbo96wr's Avatar
use a regulator with guage and set it for like 30psi and if you reach that pressure it would let the pressure out into the can place a small hole on the very top of can but on the side away from the hose going to the can.
