civic to crx
Old Apr 29, 2004 | 07:03 PM
hondaboyz5's Avatar
Default civic to crx
can i swap a 89 honda civic 1.5 motor into a 91 honda crx hf. and what will i need to make it run.and i have a honda crx si head can it fit on a 1.5 and do i need to have it milled down to fit.
Old Apr 29, 2004 | 07:05 PM
MAD SCIENTIST's Avatar
Default Re: civic to crx (hondaboyz5)
just use the hf manifold
Old Apr 29, 2004 | 07:11 PM
T S R Performance's Avatar
Default Re: civic to crx (MAD SCIENTIST)
you can use the Si head and manifold. but youre going to need to change your spindles to DX or Si. Youll be fine because i have a 1.5 with a 1.6 head and manifold in my car
BTW: I have 1991 CRX Si rear disc brake set up for sale...$150
Old Apr 29, 2004 | 07:27 PM
hondaboyz5's Avatar
Default Re: civic to crx (CivicHatchSOHC)
will i need the ecu for the si head ?or the 89 civic motor?
Old Apr 29, 2004 | 07:43 PM
get 88-91 dx or Si ecu or if you want to rrev high use 88-89 INtegra LS ecu (pg7)
Old Apr 29, 2004 | 07:52 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicHatchSOHC &raquo;</TD></TR><TR><TD CLASS="quote">get 88-91 dx or Si ecu or if you want to rrev high use 88-89 INtegra LS ecu (pg7)</TD></TR></TABLE>
cannot use DX DPFI ECU with MPFI engine - i don't understand why you would need to change spindles if he keeps HF axles
Old Apr 29, 2004 | 08:01 PM
hondaboyz5's Avatar
so it doesn't have to be from that motor just from that years?
Old Apr 29, 2004 | 08:08 PM
hondaboyz5's Avatar
but did u need to have it milled down to fit or did it fit just likeit is?
Old Apr 29, 2004 | 08:14 PM
jlicrx's Avatar
couple of questions - is the Civic engine from a DX or STD? you have Si head, do you have Si intake manifold?
Old Apr 30, 2004 | 06:45 PM
hondaboyz5's Avatar
Default Re: civic to crx (jlicrx)
yes i have the si intake manifold and the wiring
Old May 1, 2004 | 10:09 AM
yeah sorry about the thing about the DX ECU. Use Si ECU or 88-89 LS ECU. You use the Si head, wiring,. You cant use HF Spindles. you need DX or Si spindles
Old May 1, 2004 | 06:50 PM
hondaboyz5's Avatar
what if i use the hf intake do i have to change the ecu? and will it fit and what spindles?
Old May 1, 2004 | 09:23 PM
nikkon's Avatar
Change the manifold on the dx motor to the hf manifold and drop it in with ALL the stock components(ecu,wiring,injectors,ect).As for changing the spindles,dont know what that guy is talking about,just use ur stock axles and ur fine.
Old May 2, 2004 | 08:34 AM
sodacan33's Avatar
Default Re: (nikkon)
i have a d15b2 block witha shaved si head that i ported an polished 91 teg tb that was polished to hell an a si intake mani, an a dx tranny. It screams for a lil 1.5
Old May 3, 2004 | 11:38 AM
hondaboyz5's Avatar
can i put the hf intake on the si head and will it work.like use the hf injectors and fuel rail and everything else?
Old May 3, 2004 | 11:48 AM
Default Re: (hondaboyz5)
might be a different bolt pattern
daniel-crx
May 4, 2009 11:14 AM
ricen civic 1
Nov 29, 2004 09:14 PM
BriansCrx
Sep 17, 2003 09:59 PM
pinoyboy204
Mar 25, 2003 09:24 PM
Java110
Feb 21, 2003 05:56 PM
