Clutch Master Cylinder Fluid, WHERE IS IT GOING!!!
Old Apr 29, 2004 | 04:14 PM
WiLLMaTiX's Avatar
Default Clutch Master Cylinder Fluid, WHERE IS IT GOING!!!
Hey people, i need a little help, i just replaced my clutch master cylinder about 6 months ago and i keep getting a pedal that sticks to the floor, ive bled it a few times. The fluid level in the cylinder fill is always losing fluid. Any idea on whats going on? By the way Im using DOT 3 fluid... Thanks
Old May 3, 2004 | 02:55 PM
WiLLMaTiX's Avatar
Default Re: Clutch Master Cylinder Fluid, WHERE IS IT GOING!!! (WiLLMaTiX)
BUMP
Old May 3, 2004 | 03:24 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Check under the dash, by the steering column for leaks.
Also put something down below the car to see if it's leaking there.
You may need to replace you're clutch MC again.
94DB8
Feb 5, 2008 09:05 PM
kupras
Feb 19, 2007 09:30 AM
candy eg
13
Dec 29, 2005 07:26 PM
EJ8 GSR-T
Jan 17, 2005 03:41 PM
94TeGsR
Jan 14, 2003 09:00 AM
