Toda B's
What u guys think about these cams? Are these cams in good shape? Is it worth it to slap these cams in a stock us itr? i need to know before i get them.
these are the cams i found for sale:
http://www.imagestation.com/al...nvite
these cams have 1500 miles{not sure}.
Modified by ULTRADX at 3:34 AM 4/30/2004
Modified by ULTRADX at 5:48 AM 4/30/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nY's FiNeSt »</TD></TR><TR><TD CLASS="quote">whats done to the head? if it's stock i wouldn't throw them in</TD></TR></TABLE>
as long as he gets upgraded valvesprings and retainers he will be fine. They are awesome cams. Here is my jdm gsr motor, which was quite close to a usdm itr motor when this dyno was done, heres the mods:
jdm gsr 10.6:1
skunk2 mani
itr tb
jdm type r header
toda b's
portflow inner, itr outter, ti retainers
hondata
done open header. check out the tq, and the power came in really quick as well
btw check out my tq curve...127 at 2500 rpm, never drops below 125 and is nice and flat
jdm gsr 10.6:1
skunk2 mani
itr tb
jdm type r header
toda b's
hondata
nice dyno, but the toda b's top out at 8300.
i dont see why i would need to replace the stock itr valvesprings with some beffy ones if the cams don't produce power beyong 8400.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ULTRADX »</TD></TR><TR><TD CLASS="quote">I dont see why I would need to replace the stock itr valvesprings with some beefy ones if the cams don't produce power beyong 8400.</TD></TR></TABLE>
Because Toda recommends bigger valve springs with 'B's and 'C's. But it's your funeral.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaGuy02 »</TD></TR><TR><TD CLASS="quote">wouldnt he be alright with just some portflow inners with itr outers?</TD></TR></TABLE>
I hope so-I am going to try out some Toda 'C's with ITR outers and Portflow inners. Tom (Portflow) said that the ITR inners bind at about 12mm of lift.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ULTRADX »</TD></TR><TR><TD CLASS="quote">nice dyno, but the toda b's top out at 8300.
i dont see why i would need to replace the stock itr valvesprings with some beffy ones if the cams don't produce power beyong 8400.</TD></TR></TABLE>
That is not true about topping out at 8300.
I had a stock B16 that made power over 8500 with toda B.
Also I noticed that there is a double "B" stamped on the cam.... Mine is clean and only stamped once. There are some copies out on the market that look pretty close to the same.
i would definitly get upgraded springs and retainers, not positive that theyll bind on stock, but its not worth taking that chance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey »</TD></TR><TR><TD CLASS="quote">i would definitly get upgraded springs and retainers, not positive that theyll bind on stock, but its not worth taking that chance</TD></TR></TABLE>
Well i think it also depends on how high you plan on reving. Wont that determine weather a whole new valvetrain is necessary?
Well i think it also depends on how high you plan on reving. Wont that determine weather a whole new valvetrain is necessary?</TD></TR></TABLE>
No, j00 need toda valve springs because of the spec B's high lift.
A while back there was an article that was released by toda discussing that there are copy-cat cams out there.
I would recommend upgrading the valve springs and retainers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by regamaster »</TD></TR><TR><TD CLASS="quote">A while back there was an article that was released by toda discussing that there are copy-cat cams out there.
Here j00 go:
http://www.todaracing.com/topi....html
Here j00 go:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo »</TD></TR><TR><TD CLASS="quote">
No, j00 need toda valve springs because of the spec B's high lift.</TD></TR></TABLE>
portflow inner and itr outter will work
B18Redline
Jan 2, 2005 08:22 PM
