ebrake cables
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cEF9 »</TD></TR><TR><TD CLASS="quote">would crx si ebake cables work on a civic dick swap?</TD></TR></TABLE>
Pervert
Pervert
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cEF9 »</TD></TR><TR><TD CLASS="quote">DISK SWAP NOT DICK MY BAD ON TYPING</TD></TR></TABLE>
LOL!! It would appear that it would, but I have heard of people using 90-93 Teg e-brake cables on hatches.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnieChimpo »</TD></TR><TR><TD CLASS="quote">I've got Teg E brake cables. I would rather have the CRX cables.
TRADE?</TD></TR></TABLE>
btw, JohnnieChimpo i'll trade you my e-brake cables from my 89 si.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0eKnEe »</TD></TR><TR><TD CLASS="quote">So the 90-91 crx si e-brake cables will work on 2000 civic si rear discs swap as well? Driving around with no e-brakes sucks major ****.</TD></TR></TABLE>
If you have a crx they will/should.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">
Gimme your e-brake cables!
</TD></TR></TABLE>Gimme your e-brake cables!
if you have a crx..try to get the e-brake cable from a 91 si (only the 91 si model come with rear disk brake, stock)...but if you use the crx e-brake cable on any other car, it will work but it too short casuing the caliper to lock in on the rotor..making the car non-moveable even if the hand brake is dow..you can use any other intergra/civic that has rear dick setup cable but it'll be a lil longer cause the crx is pretty small...
int his pic you would want to get parts 9 and 13. this is if you ahve a crx only. crx cables, as nick stated, are too short for use on a hatch and teg cables are too long for a rex. buy 9 and 13 if you have a rex. if you ahve a hatch you use teg cables. cross tehm in the middle so the cable from the right side of the vehicle is connected to the left side of teh parking brake lever and vice versa for the other cable. that seems to take the extra slack out of tehm and they work perfect then.
HamiltonRex
Apr 23, 2004 04:18 PM
NikoZai
16
Mar 12, 2004 12:04 AM
