ITR LOWER TIE BAR
Old Apr 29, 2004 | 01:53 PM
Transport's Avatar
Default ITR LOWER TIE BAR
the oem itr ones mounts on the bottom of the lower control arms instead of the usually side like all the other cars. i have a 94 integra rs, cant i mount the itr on it? or can i only put on regular lower tie bars?
Old Apr 29, 2004 | 02:54 PM
Transport's Avatar
Default Re: ITR LOWER TIE BAR (Gr8GrZ)
no1 knows?
Old Apr 29, 2004 | 03:40 PM
ThePro's Avatar
Oops. I didn't know the ITR came with a lower tie bar...
Modified by ThePro at 10:20 AM 4/30/2004
Old Apr 29, 2004 | 03:47 PM
Transport's Avatar
Default Re: (ThePro)
the ITR does come with a lower tie bar and a trunk bar, the lower tie bar mounts on the bottom of the lower control arm, not the side of the lower control arm like other. its not polished metal though, so ppl dont usually notice it. passwordjdm confrimed with me, and i checked one out in my neighborhood, its just not bling bling thats all, no1 noticeses it
Old Apr 29, 2004 | 04:49 PM
R.S.'s Avatar
Default Re: (Gr8GrZ)
yea the itr does have a lower tie bar, but i thought that u could only use it w/ the itr rear subframe. the itr rear sub frame is dif from other integras
Old Apr 29, 2004 | 04:59 PM
jonsteR's Avatar
Comptech made a lower tie bar years ago that mounts in the same place as an itr. Drilling is required. This was before they had the tie bar & sway bar kit.
Old Apr 29, 2004 | 06:03 PM
Transport's Avatar
Default Re: (R-Spec)
what if i weld it onto the subframe???
Old Apr 29, 2004 | 06:11 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThePro &raquo;</TD></TR><TR><TD CLASS="quote">The ITR didn't come with a lower tie bar</TD></TR></TABLE>
Funny...mine did.
Old Apr 29, 2004 | 06:15 PM
Comp97GSR's Avatar
Default Re: (Kendall)
If you want it so bad, why not replace your rear subframe with the R subframe and then you can also go with a BIG rear swaybar.
Old Apr 29, 2004 | 06:17 PM
Transport's Avatar
Default Re: (Comp97GSR)
i rather weld it on hahaha
Old Apr 29, 2004 | 07:59 PM
JDC2's Avatar
you'll need the itr subframe to use the lower tie bar. It better just to get some aftermarket piece then welding a new subframe.
Old Apr 30, 2004 | 08:46 AM
Transport's Avatar
Default Re: (JDC2)
you mean i cant weld the ITR lower tie bar onto the reg integra subframe? it wont fit?
Old Apr 30, 2004 | 08:49 AM
IntEGNYC's Avatar
you wont really see a noticible difference with the bar if you already have the ITR Rear sway.
Old Apr 30, 2004 | 08:52 AM
Transport's Avatar
Default Re: (IntEGNYC)
well the lower tie bar just help to keep the to two rear wheels on the ground thats all. so does anyone know if i can weld the ITR lower tie bar into a reg integra subframe?
Old Apr 30, 2004 | 08:55 AM
IntEGNYC's Avatar
there's a lot of labor involved. its a toss up between striping and modifying your current subframe or removing it and replacing it with an itr one...
IMHO, not worth the $
Old Apr 30, 2004 | 09:09 AM
Transport's Avatar
there is? i thought i just weld that crap onto the reg integra subframe
Old Apr 30, 2004 | 10:23 AM
jonsteR's Avatar
You can do it if you want to. I've seen a DA with an ITR lower tie bar. Just weld the tabs on the subframe and bolt the bar on to it.
Old Apr 30, 2004 | 01:45 PM
WhoisDan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gr8GrZ &raquo;</TD></TR><TR><TD CLASS="quote">what if i weld it onto the subframe???</TD></TR></TABLE>
why do that? just buy one for your car.
Old Apr 30, 2004 | 03:59 PM
Italiano 2KGS's Avatar
Default Re: (whoisdan)
I have a DC sports Tie Bar and i installed it with a friend. It took us 2 hours b/c we didn't know what to do and it was hard to get the arms back in the same spots. What is easy to forget about the ITR's is that they are 5 lug and that and different suspention parts, not all ITR parts can work with all other integra's. I would say just get none Type R stuff. There is a point when your buying things on line and they ask if its a type R or Vtec or non-Vtec. Because the parts are different. The bar might work but i would believe there would be some customizeing invovled to make it work. But i just drive a 2000 GS i might be wrong, and the GSR's and the same as the R's.
Old May 1, 2004 | 01:17 PM
piatl7il77's Avatar
I have the lower ITR tie bar and trunk bar....pm me and we can meet up
Old May 2, 2004 | 01:29 PM
Transport's Avatar
Default Re: (piatl7il77)
pm sent
Old May 2, 2004 | 01:39 PM
:jdmshmaydm:'s Avatar
There was a thread on here with someone who actually bought the rear subframe piece from Acura and welded it to his non R. He then bolted on the rear tie bar that comes stock. It's alot of work and you have to like drop your gas tank and stuff to do it from what I remember.
Old May 2, 2004 | 02:20 PM
Transport's Avatar
Default Re: (Gatecrasher20AF)
thats a lil too much for me
Old May 2, 2004 | 02:40 PM
P1mpSlap's Avatar
If anyone wants a ITR lower tie bar, I have one for sale. PM me.
Old May 2, 2004 | 03:04 PM
SneezR's Avatar
Default Re: (P1mpSlap)
why go thru all that trouble trying to install the stock itr tie bar when you can simply make a purchase on an aftermarket bar that would yield similar if not better stiffness
