Fuel pump problem
Old Apr 29, 2004 | 11:07 AM
Magick211's Avatar
Default Fuel pump problem
Ive had a problem with my car not starting for a while, i replcaed fuel injectors and distributor. still had the same problem
I had around $3.00 worth of gas in the tank and for some reason i decided to put about $5.00 more in there and now it will try to start just a lil but still wont start
do u think this could be a fuel pump probelm? i can hear it prime up but im still thinking its a fuel pump problem.
also i replaced the fuel filter
Old Apr 29, 2004 | 11:13 AM
LudeEFv2.4's Avatar
My old title sucked.
Default Re: Fuel pump problem (CivicBoyZC)
when did this problem start, just out of the blue one day? or were you doing something mechanical to the car and now it doesn't run. basicaly, what makes you think it's a fuel related problem?
Old Apr 29, 2004 | 11:16 AM
Magick211's Avatar
Default Re: Fuel pump problem (LudeEFv2.0)
well since it already had some gas in it. and i decided to put more in it then it tried to start a lil. and sounds like its starving for ruel main relay is good too
It was running fine a few months ago and day by day it sarted running worse finally it woudnt start anymore
I replaced thought it was the ignitor so i tried my friends distributor off his car, replaced plugs and wires, main relay and fuel filter. but when i put over 5.00 in gas plug what was in there it trys to start a lil now but sounds like its starving for fuel
compression is good on the motor too
Old Apr 29, 2004 | 12:11 PM
Magick211's Avatar
TTT
Old Apr 29, 2004 | 12:26 PM
b16_madman's Avatar
Sounds to me like your tank is cloggged up on the pickup or something, but that's just a stab in the dark.
Old Apr 29, 2004 | 12:34 PM
Magick211's Avatar
Default Re: Fuel pump problem (B16_madman)
how would i check drop the tank?
Old Apr 29, 2004 | 09:18 PM
eda6's Avatar
Install a fuel pressure gage on your fuel filter and then try to start the car.
This will help you troubleshoot the problem. It got worse day to day. Sounds like your fuel pump failed. I know you hear it prime up, that just means it got power. If it's a daily driver then the lines shouldn't get clogged. Check for kinks in the supply/return lines. If you have good pressure, replace fuel pressure regulator.
Modified by 88 SiR at 6:31 AM 4/30/2004
Old Apr 29, 2004 | 10:45 PM
B2FiNiTY's Avatar
Default Re: Fuel pump problem (88 SiR)
Have someone try to start your car while putting pressure on the fuel hose to see if it has pressure.
Old Apr 30, 2004 | 06:28 AM
Magick211's Avatar
Default Re: Fuel pump problem (B2FiNiTY)
I think im gonna borrow my friends fuel pressure guage. what pressure should i be at if the fuel pump is good? crx dx
Old Apr 30, 2004 | 04:08 PM
eda6's Avatar
About 36 psi.
Old May 1, 2004 | 09:44 PM
Magick211's Avatar
Cool thanks for the replys
Perkul8r
Aug 4, 2009 10:57 AM
eh2Ry
Aug 6, 2008 07:10 AM
dxhatch93
Nov 17, 2005 01:12 PM
SoCal ITR
May 6, 2004 10:27 PM
