b18A1 swap into a 92 civic DX HB. Need some advice!
The engine is mounted in the chassis. I need help with wire harness, do I need to change all harnesses because the plugs do not match around the ignition? So do i need integra ignition and accessory fuse box or should the civic box work?
Modified by shlizzle at 10:12 PM 4/29/2004
camoner
Sep 12, 2011 02:03 AM
