My 1st 1/4 Time with new motor..CRVtec
Old Apr 29, 2004 | 08:00 AM
Se-rv-Tak's Avatar
Default My 1st 1/4 Time with new motor..CRVtec
Well I went to the track last night, and ran my best 14.29
My setup....
B20b Block(stock)
B16a3 head(stock except for GSR cam)
Skunk2 IM
An-R Compact Header (open)
Crane Cam Plug wires(POS!!! NEED TO CHANGE THOSE!)
AEM short Ram
My best MPH was 101.3 But I think that was with a 14.4 pass...... with a 2.5 60'
I just want to see everyones opinions on this..... Thanx.
Old Apr 29, 2004 | 08:10 AM
4door-r's Avatar
Default Re: My 1st 1/4 Time with new motor..CRVtec (Se-rv-Tak)
you could improve on your 60 ft. times. what tranny are you using?
Old Apr 29, 2004 | 08:22 AM
RobbieG35's Avatar
12 Years Strong
Default Re: My 1st 1/4 Time with new motor..CRVtec (4door-r)
Yea the 60ft. needs to come up, pull a better 60 and 13s should be easy
Old Apr 29, 2004 | 08:26 AM
DEVIOUS_EG*'s Avatar
were you using slicks?..
Old Apr 29, 2004 | 08:32 AM
4door-r's Avatar
Default Re: My 1st 1/4 Time with new motor..CRVtec (DEVIOUS_EF*)
i hope not.
Old Apr 29, 2004 | 08:34 AM
Se-rv-Tak's Avatar
good im glad all you thought the same thing...... 1st off im using the b16a3 tranny....I forgot the code for it..... I think y21 but im not sure. Slicks... no... shitty *** sumitomo tires.
Reasons for shitty 60'
Driver side Axle busted, it has been spewing out grease for about a week now.... and I get wheel hop while going in reverse
I have no a/c bracket that act's as a front mount.... I only have the tranny side.
And like I said earlier my sumitomo's on steelies... SUCK! spining thru 2nd... really sucked... lol
My 60's will improve big time.... im hoping on some Jimfab traction bars... a new axle, some sort of fabricated mount bracket for the a/c.... and maybe some better tires if I can afford it.
Old Apr 29, 2004 | 08:47 AM
4door-r's Avatar
all that stuff will help alot but it still takes skill.you could have used the stock ac bracket just cut it.
Old Apr 29, 2004 | 08:52 AM
Se-rv-Tak's Avatar
well see that's the thing i don't have an a/c bracket.... I found a guy on here that has a p72 bracket.... but I don't want to spend more money and that not work.....
My skill.... I always like to improve my skill, espcially with a new motor and such, I just need traction... and no wheel hop! haha
Old Apr 29, 2004 | 10:32 AM
C8V6C's Avatar
The tires will probably help the most
Old Apr 29, 2004 | 01:13 PM
Se-rv-Tak's Avatar
Default Re: My 1st 1/4 Time with new motor..CRVtec (C8V6C)
I personally think the traction bars will do the best.... I can borrow tires when it comes down too it...
91tegrals's Avatar
nice times wat car is this motor in
Old Apr 29, 2004 | 01:33 PM
Soda Popinski's Avatar
Default Re: (91tegrals)
Prolly got such a high trap cause of the steels, on normal sized rims and good 60fts i predict you can run 14.1 or 14flat.
Old Apr 29, 2004 | 03:11 PM
see_our_vtec's Avatar
Default Re: (BeeBeeOne)
those are his normal sized rims, the car is a 97 civic dx coupe.
Old Apr 29, 2004 | 03:15 PM
.RAven's Avatar
man! I cut 2.1 on my 205/60/13 sumitomo's all day.
Old Apr 29, 2004 | 03:24 PM
getgot22's Avatar
Default Re: (Von Dutch)
what chassis is this in? coup, hatch, wha?
Old Apr 29, 2004 | 03:31 PM
Se-rv-Tak's Avatar
Default Re: (getgot22)
EJ6 Coupe.
I am running 195/60/14 sumitomo's....
and don't you all worry 13's are for my next time at the track.
Old Apr 29, 2004 | 08:16 PM
vivid02's Avatar
Default Re: (Se-rv-Tak)
damm you should fix your shortcommings and run it again. You will see 13's no problem
Old Apr 29, 2004 | 08:20 PM
CompressionFed's Avatar
Default Re: (vivid02)
That trap speed netted me a 13.5 on Azenis...you have the power, just put it to the ground!
Good luck
Old Apr 29, 2004 | 09:02 PM
InitialDSR's Avatar
Default Re: (CompressionFed)
Nice time slips....
Old Apr 29, 2004 | 09:23 PM
Se-rv-Tak's Avatar
Default Re: (InitialDSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CompressionFed &raquo;</TD></TR><TR><TD CLASS="quote">That trap speed netted me a 13.5 on Azenis...you have the power, just put it to the ground!
Good luck</TD></TR></TABLE>
Ya I know trust me I know.... I was running on 3 cylinders a few days ago, because one of my plug wires popped off my dizzy... and I beat a... a i/h/e integra LS..... so I know something is right .... if I can do that.. lol
Old Apr 30, 2004 | 08:03 AM
specie's Avatar
That's a nice trap speed for your setup. How much does the '97 Coupe weigh? 2500-2600lb?
Old Apr 30, 2004 | 04:31 PM
Se-rv-Tak's Avatar
Default Re: (specie)
somewhere around that weight....
Old Apr 30, 2004 | 06:34 PM
ISawUL00k's Avatar
thats slow. u need a fuel pump if you dont have one already. you should run alot faster i would think.my b18 stock in my hactch went high 13's on street tires..
Old Apr 30, 2004 | 11:43 PM
Joseph Davis's Avatar
Default Re: My 1st 1/4 Time with new motor..CRVtec (ISawUL00k)
At stock rail pressure, he doesn't need a fuel pump until 300 whp.
Old May 1, 2004 | 12:42 AM
keep in mind, traction, weight, altitude and weather, at sea level he's in the 13's easy.
