89 Teg Motor into 91 CRX SI???
My buddy has a 89 tegra that was wrecked. Engine still good though. Will his engine bolt up to my car like a real zc would. I believe his engine is a d16a1. I could probably get both the engine and ecu for like 200 which is like 400 less than a zc and almost the same damn thing. Oh and i know its in good running condition cuz I helped him change the spark plugs/wires and go through the engine. Any one who can help me please do so I want....no...NEED MORE POWER! And this just seems like a low-cost way to go.
I dont think the d16a1 is a bolt in affair unless you have a 1G CRX/3G Civic. Search the archives, there should be tons of info. on this
https://honda-tech.com/zerothread?id=836878
https://honda-tech.com/zerothread?id=720027
^^^Many more if you search.
What about if I swapped the ecu from his 89 teg to my rex. Will it work? and will it make a diff. I heard somewhere that it gives a lil bit more getup
What i need to know is if his ECU will boost the performance of my car with my stock motor. Later Ill probaly do a b16 for 3200 out the door later on. Is 3200 too much? and the ecu thing is for now so NO ZC swaps at the moment
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spyz34 »</TD></TR><TR><TD CLASS="quote">NEED MORE POWER!</TD></TR></TABLE>
That 89 teg came rated at 118 crank hp for an LS or RS model, 125 if it was the SE model.... Only a ten hp gain. Ain't worth it.
illogic65
Oct 1, 2004 12:32 PM
Heavy Pee
Aug 7, 2002 03:30 AM
