How much whp and tq with 11.1:1 CR?
Sup guys.
It seem like this forum you guys know alot about All motor. I was wondering how much power and torque i'll get at the wheels with a 11.1 CR on a B16A2?
you should be able to hit 200 whp..this is a very generous estimate though..so many variables..proper engine prep, breathing and so on..take your time..research, and invest in the best( not always the most expensive) equipment for your engine....sorry for the vague answer..hope this helps..
good luck!
good luck!
This question cannot be properly answered without a list of mods. Expect more than a stock B16A. That is the only answer you can get with such a vague question.
11.1CR isn't really that high. The stock JDM ITR have 11.1CR and it have like 200hps at the crank. So if your B16A is stock, my guess would be around 145whps with 11.1CR alone. But I would assume you would have other mods beside the higher compression piston, right?
1990hondaHF
Apr 8, 2004 11:38 PM
