GSR coupe track time
Old Apr 28, 2004 | 08:36 PM
93gsrcoupe's Avatar
Default GSR coupe track time
I'm going to the track for the first time on Friday and wanted some info. I have a 93 civic coupe with a USDM 95 gsr swap with cold air intake and catback exhaust. I am also putting my stock dx wheels on instead of my heavy 17" rims. What should I run? Should I shift at 7600 or 8000? At what rpm should I launch at? And does anyone have any other advice for a first timer?
Old Apr 28, 2004 | 08:46 PM
FerioVtec94's Avatar
i would guess mid-high 14s if you can get some decent 60fts, you should be able to launch between 2500-3500...start low and work your way up, you are gonna want some spin off the line and enough that it doesnt bog after you hook, shift at 8k
Old May 1, 2004 | 04:21 PM
93gsrcoupe's Avatar
Default Re:
Here are my results from last night:
R/T=.737
60'=2.417
330=6.589
1/8=10.001
MPH=72.06
1000=12.921
1/4=15.394
MPH=89.89
That was my second run, on my first I ran a 15.5 because of a bad start. I've gotta practice starting before I go back.
Old May 15, 2004 | 09:38 PM
vivid 02's Avatar
Default Re: Re: (93gsrcoupe)
work on your launches. your 60ft is too high. drop that biatch to 2.2's at least and you will see your 1/4 times drop
Old May 16, 2004 | 07:25 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93gsrcoupe &raquo;</TD></TR><TR><TD CLASS="quote">Here are my results from last night:
R/T=.737
60'=2.417
330=6.589
1/8=10.001
MPH=72.06
1000=12.921
1/4=15.394
MPH=89.89
I am going to say that someone messed up something with your swap. Dunno what as I can't see it, but you should be trapping a HELL of a lot quicker then 89mph.
Old May 16, 2004 | 08:34 AM
tyflip2's Avatar
Default Re: Re: (Hybrid93Eg)
i have a 96 hatch with gsr swap and with just a 2.3 60ft i was pulling consistent 14.8's and occasional 14.7's. i know if i get a better launch my times will be higher. i was trapping at 93. hope this helps you
Old May 16, 2004 | 08:53 AM
Rod.'s Avatar
Default Re: Re: (tyflip2)
get some slicks
Old May 16, 2004 | 10:56 AM
Adam.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
I am going to say that someone messed up something with your swap. Dunno what as I can't see it, but you should be trapping a HELL of a lot quicker then 89mph. </TD></TR></TABLE>
He had a 2.4 60ft. I would be in high 14s if he dropped that a bit. Also, he's in a coupe not a hatch = Heavier.
Old May 16, 2004 | 11:10 AM
boostsohfast's Avatar
Default Re: Re: (DarkKnight[DMD])
Did you get a chance to weight the car?? I understand that it is a coupe but that trap is still considerably low for what he has.
Old May 16, 2004 | 11:48 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight[DMD &raquo;</TD></TR><TR><TD CLASS="quote">]
He had a 2.4 60ft. I would be in high 14s if he dropped that a bit. Also, he's in a coupe not a hatch = Heavier. </TD></TR></TABLE>
The 60 should have nothing to do with his traps being THAT much lower then they should. That should trap around 93-94 even in a coupe... which by the way isn't but maybe 200lbs heavier the the almighty hatch.
And just to help you out some. Even if he DID cut a 2.3 60, then he would run 15.1... Still slow for what it should do if you ask me.
Old May 16, 2004 | 02:25 PM
BlownVR's Avatar
well i can see why you did those times though. You were on the stock wheels. They are so skinny he probably could get ANY traction. i think with some drag radials you'll be in the low 14's with a semi-stripped car
Old May 16, 2004 | 03:24 PM
hondaguyef's Avatar
Default Re: Re: (redturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">get some slicks</TD></TR></TABLE>
Old May 17, 2004 | 10:33 AM
yaaj1320's Avatar
Default Re: GSR coupe track time (93gsrcoupe)
i have a 92 dx hatch with a stock usdm gs-r..( open header).just no back seats and im running 14.2@99 mph..my 60ft times are 2.2...and that was on 17's...with some shitty kumho tires..try urs with open headers and there will b a difference..high 14's..
Old May 17, 2004 | 10:43 AM
hybridEj6's Avatar
Default Re: GSR coupe track time (yaaj1320)
try lowering your 60ft. When i first got my swap i hit 14.87 w/ 2.360ft with i/h/ex clutch and flywheel in a 99 coupe with full interior
BlownVR's Avatar
yeah i dont know if open header does too much i ran like that for a while and still had the same times... because you lose a little mid range, but if you can manage to stay above likr 4800 then it is better with the open header..
Old May 17, 2004 | 02:56 PM
1point5CRX's Avatar
Default Re: (H22BuiltEGhatch)
dayum, i ran 15.1@90 with my sohc zc a while back i/h/e/pg7. you should be moving for having a gsr motor
Old May 17, 2004 | 03:45 PM
londa hover's Avatar
And just to help you out some. Even if he DID cut a 2.3 60, then he would run 15.1... Still slow for what it should do if you ask me.</TD></TR></TABLE>he might live in high elavation.
i have a eg hatch with b18c1 w/ bolt ons skunk2 camshafts and hondata(185.4whp 133.1tq) and my best time is 15.2@90 w/ a 2.02 60ft. at 4750 ft. above sea. stock integra gsr's have a hard time breaking in to the 15's
clutch6racerone
Apr 3, 2007 08:11 AM
bustdgst
Oct 13, 2006 07:43 AM
eghondafamily
Sep 6, 2006 04:03 PM
D-Rob
Mar 22, 2006 08:00 AM
Honda Kustums
24
Jun 6, 2003 10:31 PM
