Upper radiator hose swollen like hell! HELP!
Old Apr 28, 2004 | 07:02 PM
accorddx's Avatar
Default Upper radiator hose swollen like hell! HELP!
See attached pic. The hose swells as the coolants warms up. It just happened today after i opened the radiator cap and add a little bit of coolant to the reservoir. What happened?? I was thinking there might be trapped air, then i run the car with the radiator cap off and sqeezed the upper hose. But now I couldnt really tell if i fix the problem since the hose seems seems like damaged and wont return to its normal size.
Modified by accorddx at 4:52 AM 4/29/2004
Old Apr 28, 2004 | 07:06 PM
-RedneckDave-'s Avatar
Working
Default Re: Upper radiator hose swollen like hell! HELP! (accorddx)
Put a new hose on and the problem is solved.
Old Apr 28, 2004 | 07:43 PM
fizzbob7's Avatar
Default Re: Upper radiator hose swollen like hell! HELP! (01accordv6)
hoses swell either when they are horny or when the inside breaks down, which will happen to most of the worlds rubber hoses eventually.....it will pop if you don't replace it and you may very well die of burns
Old Apr 28, 2004 | 07:46 PM
The_Todd's Avatar
Farts in the shower
Old Apr 28, 2004 | 07:47 PM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01accordv6 &raquo;</TD></TR><TR><TD CLASS="quote">Put a new hose on and the problem is solved.</TD></TR></TABLE>
The hose has gotten weak, you need a replacement ASAP before it blows and you have coolant ALL OVER your bay.
Old Apr 28, 2004 | 07:57 PM
accorddx's Avatar
Default Re: Upper radiator hose swollen like hell! HELP! (VRDrvr)
Thanks VRDrvr for the image trick. Certainly I will replace the hose tomorrow. I was just wondering why it could happen in out of a sudden and worried if it had something to do with taking off the cap earlier.
Old Apr 28, 2004 | 09:38 PM
Monkey Fing a Coconut's Avatar
damn...it looks like a snake after it just ate a rat
chawski
Honda Civic (2001 - 2005)
Jan 1, 2014 02:20 PM
91EF_Si
Jun 27, 2008 04:38 AM
aziaticvang
Feb 1, 2008 09:34 AM
billy hoang
Jan 21, 2007 01:17 PM
huntarrr
Dec 14, 2006 03:51 PM
