just installed vortex front spocket on my f4
Old Apr 28, 2004 | 01:52 PM
luvinmyGSR's Avatar
Default just installed vortex front spocket on my f4
i just finished installing my front spocket on my 00'cbr 600 f4. iwent with the vortex -1 in front. it feels alot better in first the rpm's really climb very fast now.i am shifting alot more often. and my speedo is prolly about 10 mph off. but i don't care i love this sprocket. on question though i had to tighten my chain after i put the sproket on and the index line is right on the replace chain mark on the chain tensioner thing. do i have to replace my chain now or not because it's still alittle loose i prolly need to go another half on turn on each chain tensionerto get it within spec. so do i need a new chain?
Old Apr 28, 2004 | 03:26 PM
BoostedSi's Avatar
Default Re: just installed vortex front spocket on my f4 (luvinmyGSR)
it wont be in spec with the stock chain since you went down 1. I went down -2 in the front and mine says it needs replacing too. It says that cause you tightened it more since you lost an extra tooth.
Old Apr 28, 2004 | 04:42 PM
typesguy's Avatar
ok so i can tightened it alittle bit more to get the chain within spec 25 tp 35 mm. and also when i do replace my chain do i just get one with like 2 less links then the factory one or something?
Old Apr 28, 2004 | 09:06 PM
BoostedSi's Avatar
Default Re: (jaydmdc2)
yes you can still tighten it more until its within specs. It doesnt matter that it says replace chain...ur an exception since you lost a tooth. Also when you get a new chain they usually come in a length of 120 links, well most do and you just have to cut it down from there. You cant buy a chain with the exact amount of links you want on it. You have to cut it down.
Old Apr 28, 2004 | 10:40 PM
.xcalibur.'s Avatar
Default Re: (BoostedSi)
When replacing sprockets, its a good idea to replace both front and rear sprockets along with a brand new chain. Once on the bike, they all mate together. The chain will break in to the new sprockets and vice versa. You shouldnt only replace 1 or 2 of this bunch even if you keep the stock number of teeth on one of the sprockets. Just a tip ive learned from other forums.
Sliced Beard
Honda Motorcycles
Mar 24, 2008 07:49 PM
BoostedEgHatchFl
Honda Motorcycles
Nov 5, 2005 11:49 AM
flashmang
Sep 3, 2005 09:41 AM
TypeRlove
Jun 8, 2005 05:43 AM
