flywheel grind specs for exedy clutch.. Please help..
I just bought one of the Exedy 3 puck clutches (08902b) for a 90-91 civic-crx.. I need to get my flywheel ground for the clutch.. I called Exedy and they said .061 but that doesnt sound right..
Also the guy I talked to said the mounting side is to be ground higher than the friction side.. Im assuming thats either a negitive or positive stepping but I dont know if thats the terms used by the machine shops or not.. If not then whats it called and is the .061 stepping correct??
