How to improve brake setting on 5g for daily/occasional track use.
Hi All.
This is my first posting here. My name is Johnny and I own a 5g SH. I recently took my car to Summit Point Raceway (WA) in their FAATT event and it was a lot of fun (also learned quit a bit about the car.) My car is stock and I like how it drives. However, the brakes could use some improvement for the track and I am trying to find out what I can do to make them improve on the track yet still good for everyday (commuting) city traffic. Someone suggested that I should change the brake fluid to the high performance kind (ATE Super Blue) and upgrade the pads to Carbotech Panther. I was doing research on the web and there seem to be some mixed reviews on them. I want to know if anyone had any experience in them or is there a better option? Also is there anything else I can do to improve the car's braking performance?
Thanks,
-Johnny
Thanks,
-Johnny
The factory calipers and rotors are fine. I would suggest Porterfield R4S brake pads and Goodridge stainless steel brake lines. That combined with Motul 600 brake fluid and you will have a very nice setup.
Where can I get these?
Mike
Mike
Hi All.
Thanks,
-Johnny
Thanks,
-Johnny
Prelude brakes are right up my alley.. The carbotechs panther plus pads are GREAT pads for mainly track/some street use.. I have run them, an I am quite impressed with them, for being track and street pads... They only faded when pushed to the max with R compound tires...
I run hawk blues now, simply because I need a full race pad now, I love them, but the cannot be daily driven.. I also use ATE superblue as well, and highly recomend it..
Hope to see you at the track again
Corey
Great!
Next time I see you in the track I will definitely hook up with you. I probably will go back again early next season with some of my buddies. I will probably get some new Khumos and hopefully will get much more fun out of the track and the car
-Johnny
-Johnny
Corey[/QUOTE]
So what if my main use is "Mainly street, occassional track?" Will the Panther Plus do well under that circumstances?
Thanks,
-Johnny
Thanks,
-Johnny
Thanks,
-Johnny
I ditto what Corey has said...accurate description.
Yes, the P+ can be used on the street with excellent results, but they will wear perhaps 15% faster when driven cold on the street than when driven hot on the track. Other than that...no problems. As for squeal, you can use an anti-squeal compound to aleviate any noise you experience under low line pressure or when cold.
The following car club members get a 10% discount from our list prices: S2000 Club of America, NSX Club of America, Integra Type-R Club of America, Porsche Club of America, Ferrari Club of America, BMW CCA.
We would like to work closely with other clubs or online communities, but those to which I have approached have not responded or been receptive. If you would do not belong to any of the aforementioned car clubs, but would like to receive a discount on our custom brake pads, perhaps you could ask your car community officers to drop me a line and we can chat.
Regards,
Andie Lin
Regards,
Andie Lin
..there are a few different ways to go:
Cheap:
ss brakelines [a great deal of the compliance in the brake system is in the lines]
ITR brake pads in the front
stock pads in the rear
brake fluid flush
also, if your in a real pinch and want some cheap brake fluid, Ford DOT 5 is nice, but highly corrosive, so if you use it, flush the fluid at the track, then replace it w/ OEM Honda fluid when you get home, this is where Russel speed bleeders come in handy.
Moderate:
Porterfield R4s pads
ss brakelines
motul brakefluid
Cryo treated Slotted Rotors?
nsx calipers
A little more dough:
2-piece Aluminum hat slotted rotors up front from Fastbrakes, just order the ITR rotors, same as bb6 (front only) [mostly for weight reduction]
two sets of pads: r4s for the street/r4 for the track or hawk blues
motul fluid
cryo rotors also slotted out back
spoon 4-pot calipers up front
Also, you need to remember that the brakes do not actually stop the car, the tires do, so all the pretty brake upgrades in the world only improve pedal feel, consitency and heat dissipation, so first order of business, if you haven't already, would be to get some new/better tires! Falken Azenis in 215*45*16 come to mind, since they fit the OEM SH wheel, provide good grip, and are realativly thrifty.
Hope that helps...
[Modified by bb6h22a, 3:46 PM 11/6/2001]
[Modified by bb6h22a, 3:48 PM 11/6/2001]
Cheap:
brake fluid flush
Moderate:
ss brakelines
motul brakefluid
nsx calipers
motul fluid
Hope that helps...
I would advise AGAINST R4S pads.. Brand new set was Done in 6 somewhat light sessions of track driving... I have used them all, and still say just go w/ carbotech panther plus.. hella cheaper than R4 pads and the brake dust will not chorode your paint..
SS lines are a plus.. Ford HD is great fluid, no need to mess with the Dot 5 stuff..
..I wouldn't say that the R4s is a track suited pad, more for spirited street driving.
I haven't used the Carbotech pads so, I cannot comment, and yes the Ford HD fluid is good stuff too.
sierrahiker8
16
Sep 12, 2012 06:41 AM
97CWITR
16
May 15, 2009 09:35 PM
