Torque Specs for AEBS Headstuds?
Old Apr 28, 2004 | 03:26 AM
vtecb20coupe's Avatar
B A N N E D
Default Torque Specs for AEBS Headstuds?
Okay, I've been looking for the torque specs for a set of b18c headstuds but can't seem to find it in the archives. If anyone has them, please post em. Thanks.
Old Apr 28, 2004 | 10:56 AM
B A N N E D
Default Re: Torque Specs for AEBS Headstuds? (vtecb20coupe)
anyone?
Old Apr 28, 2004 | 01:13 PM
havok hybrid's Avatar
the torgue spec will be for what ever your torquing down.. if its your head.. it would be what your head should be torgued to witch is 72 ft-lbs.
Old Apr 28, 2004 | 05:01 PM
B A N N E D
Default Re: Torque Specs for AEBS Headstuds? (havok hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by havok hybrid &raquo;</TD></TR><TR><TD CLASS="quote">the torgue spec will be for what ever your torquing down.. if its your head.. it would be what your head should be torgued to witch is 72 ft-lbs. </TD></TR></TABLE>
that's oem specs though, correct? wouldn't aftermarket be slightly higher? i'm using the aebs studs.
Old Apr 28, 2004 | 05:12 PM
ljoe's Avatar
no, motor specific. find any repair manual and it will tell you the specs, it'll be in two stages though. go around in order for the first step, then again for the final torque down.
Old Apr 29, 2004 | 12:50 AM
B A N N E D
Default Re: (ljoe)
i just want to confirm that the aebs studs do not need to be torqued any higher than oem studs. like my arp rod bolts required higher torque specs. just wanting to verify.
greddy13
Dec 28, 2006 11:40 PM
BrightRedOne
Oct 24, 2004 09:45 AM
bluebomb
Jul 13, 2004 03:04 PM
