10.5K redline Del Sol Cluster?
Old Apr 28, 2004 | 02:48 AM
Crank's Avatar
Default 10.5K Del Sol Cluster?
this sorta got my attention, anyone know where i can get this?
Modified by Crank at 2:51 PM 4/28/2004
Old Apr 28, 2004 | 03:30 AM
AdamQ3B85's Avatar
Default Re: 10.5K redline Del Sol Cluster? (Crank)
It kind of looks like if redline starts at 9.5 or so, I had never seen a del sol cluster like this one before, pretty cool...
Old Apr 28, 2004 | 01:51 PM
Crank's Avatar
Default Re: 10.5K redline Del Sol Cluster? (AdamQ3B85)
yes, it does thats why im trying to get more info on this..
Old Apr 28, 2004 | 02:04 PM
Dlpz87's Avatar
I would check Honda Marine applications and motorcycle/atv's, you never know
Old Apr 28, 2004 | 02:08 PM
.hugo's Avatar
Default Re: 10.5K redline Del Sol Cluster? (Dlpz87)
yeah my guess would be that the stock tack was taken out and replaced with one from somewhere else
Old Apr 28, 2004 | 02:09 PM
Infamous_Imports's Avatar
ATV's etc would be a good place to look but i'm assuming it did come out of a Sol because it still has the little del sol image above the clock. Good luck finding it...
Old Apr 28, 2004 | 02:12 PM
B16Drag's Avatar
NO idea, but thats one BAD @$$ tach
Old Apr 28, 2004 | 02:26 PM
976's Avatar
976
New User
Default Re: (B16Drag)
No one would make a tach with 0 rpms that close to 11K rpms. I'm going to call BS - photoshop...
But if not, nice!
Looose_R's Avatar
Default Re: 10.5K Del Sol Cluster? (Crank)
the guy put a new "skin" over his existing tach. that car is old
kingSfit's Avatar
s2000 ? =p they do redline around 9
Old Apr 28, 2004 | 02:29 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (976)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 976 &raquo;</TD></TR><TR><TD CLASS="quote">No one would make a tach with 0 rpms that close to 11K rpms. I'm going to call BS - photoshop...
But if not, nice! </TD></TR></TABLE>
Did you look at the tach?? It's sitting @ 0 a good 90 degrees away from 11,000rpm. The other marks in between there apear to be warning lights of some sort.
Old Apr 28, 2004 | 02:39 PM
toddbenson's Avatar
its just a black gauge overlay
Old Apr 28, 2004 | 03:22 PM
976's Avatar
976
New User
Default Re: (Mr Milano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote">
Did you look at the tach?? It's sitting @ 0 a good 90 degrees away from 11,000rpm. The other marks in between there apear to be warning lights of some sort.</TD></TR></TABLE>
Ah, good call.
Old Apr 28, 2004 | 03:25 PM
deeksmooth's Avatar
Default Re: (976)
the cluster is from the owner of http://www.darksol.com , or darksol motorsports... its a pretty quick little NA'ed Sol. runs mid 12's i think.
EDIT: looking @ darksol.com, he doesn't seem to have a store anymore... just a BBS, Classifieds section, and a Showcase for his car.
EDIT AGAIN: if you check out this pdf file, u can see another CLOSE UP pic of the cluster. http://www.darksol.com/images/darksol.pdf
note- you will need adobe acrobat reader installed.
Modified by citrEK at 4:37 PM 4/28/2004
Old Apr 28, 2004 | 03:30 PM
barto's Avatar
Default Re: (Bunz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bunz &raquo;</TD></TR><TR><TD CLASS="quote">s2000 ? =p they do redline around 9</TD></TR></TABLE>
i think those are digital
Old Apr 28, 2004 | 08:46 PM
Crank's Avatar
Default Re: (barto)
.... i want to get one!!!!!!!
Old Apr 28, 2004 | 08:49 PM
xavior66's Avatar
The tach in that pic was most likely custom made. I know you can get them custom made. That's prolly what he had done.
Old Apr 28, 2004 | 09:00 PM
STREETWERKZ's Avatar
Default Re: 10.5K Del Sol Cluster? (xavior66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Looose_R &raquo;</TD></TR><TR><TD CLASS="quote">the guy put a new "skin" over his existing tach. that car is old</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toddbenson &raquo;</TD></TR><TR><TD CLASS="quote">its just a black gauge overlay</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xavior66 &raquo;</TD></TR><TR><TD CLASS="quote">The tach in that pic was most likely custom made. I know you can get them custom made. That's prolly what he had done.</TD></TR></TABLE>
Old Apr 28, 2004 | 09:02 PM
EG2 SiR's Avatar
Default Re: (Crank)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crank &raquo;</TD></TR><TR><TD CLASS="quote">.... i want to get one!!!!!!!</TD></TR></TABLE>
Buy my JDM one.... it's JDM yO!
Old Apr 28, 2004 | 09:12 PM
da935oul's Avatar
i think the tach is too good to be tru, unless he modified it and had black paint to cover up the rest of the redline from 8 to the 10.5.
Old Apr 28, 2004 | 09:19 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: 10.5K Del Sol Cluster? (da935oul)
probably a gauge face overlay. looks like whoever did it did a good job
Old Apr 28, 2004 | 10:24 PM
ek4hatch's Avatar
Default Re: 10.5K Del Sol Cluster? (AzntaggeR)
Old Apr 28, 2004 | 10:26 PM
ek4hatch's Avatar
Old Apr 28, 2004 | 11:00 PM
mooseknuckle's Avatar
looks bad ***. I like my stock S tach tho. Shifting in the red owns.
Old Apr 29, 2004 | 01:14 AM
Crank's Avatar
Default Re: 10.5K Del Sol Cluster? (mooseknuckle)
damn im still hella intrested at this!!!!
