Prelude calipers on EK
Old Apr 27, 2004 | 10:35 PM
colinproctor's Avatar
Default Prelude calipers on EK
I have a 97 Civic that i am puting a h22 into. I bought a 97 Prelude Type SH that is wrecked a little in the front, but motor and trans are fine. Obviously to use the motor for the swap. I was trying to swap the calipers from the Prelude to the Civic for the size difference, seeing that i will need more braking power. The dilema that i am having is i dont know what rotors to use, for the Civic having four lug and i want it to stay that way and what will be the same size as the stock Prelude rotors. Also will the calipers on the Civic clear the wheels. If anyone had any information on this brake swap it would be great. Thanks.
Old Apr 27, 2004 | 10:53 PM
tinkerbell's Avatar
Default Re: Prelude calipers on EK (FdOoUoRr)
re-drill the prelude rotors to the same stud pattern as the EK,
then you might have to get a bracket machined to fit the calipers on the hubs...
but i havent done this - this is jsut what you would normally do to swap brakes across models...
you might need at least 14's or 15's to fit the brakes...
Old Apr 27, 2004 | 11:10 PM
yea i though about that but it just doesnt sound to safe
i wanted to find another rotor from something else to work so ican just bolt it up
i heard something about GSR rotors are the same? anyone know?
Old May 5, 2004 | 09:38 PM
Default Re: (FdOoUoRr)
anyone else have any information regarding this brake swap, please post it it would be of great help.
Old May 5, 2004 | 09:51 PM
Ejsleepin's Avatar
hey, im new to this sight and we are doing the same swap. i need to get my fuel and vacuum lines done but dont have a manual for j-spec h22a. do you know if i can refer to USDM version for the mock up?
Old May 5, 2004 | 10:09 PM
Default Re: (Ejsleepin)
this should help you out alot
https://honda-tech.com/zerothread?id=650329
Old May 6, 2004 | 03:45 AM
1700anddroping's Avatar
i have done the samw thing on my h22 stroked and turboed hatch.i just used the aero cross drilled for the 92-95 civic.the set up worked better than i thought it would.i am now in the process of doing the back.i have 17" volk's se's on it with no problems.i have even put the nitto 555 extremes on to and they are 14" and they clear also.hope this helps.
93 hatch cx w/h22 stroked to a 2.4L
w/ xs t67 bb w/pro race fogger shooting for 700+ with the gas
car will be dynoed a week from fri.wish me luck.
Old May 6, 2004 | 04:16 AM
Kal's Avatar
Kal
gsr rotors are different from prelude rotors... itr and prelude use the same rotor.
tooth_dr
Suspension & Brakes
May 3, 2009 12:25 AM
freeburn
Dec 6, 2008 08:28 AM
90jdmda90
May 14, 2008 06:19 PM
EK4door
28
May 17, 2004 07:45 PM
VSMHatcH
Apr 26, 2004 02:48 PM
