new here need advice..
Old Apr 27, 2004 | 10:35 PM
xjun10rx's Avatar
Default new here need advice..
hey whats up guys ... im new to this forum i come from jmi... now i recently purchased a 88 crx hf... well the body... and the guys registration expired on nov 03... so what do i tell the dmv? cause to register dont i need to smog and stuff... and im not putting a gsr motor till another month or more.... so what do i do...any advice or something?
Old Apr 27, 2004 | 10:49 PM
Mr_CRX's Avatar
Default Re: new here need advice.. (xjun10rx)
you can go to the DMV and put it on "non-operational" status until you finish your motor swap. That's what I did cause my smog came up this month and my stock motor had already been yanked. When I finish the swap, then I'll go to the referee and get it all BAR approved and finish up the registration.
Old Apr 28, 2004 | 01:15 AM
DA_Junkie's Avatar
now thats why i love washington & oregon
no smog bs
Old Apr 28, 2004 | 01:35 AM
xjun10rx's Avatar
so i have to go get refereed once im done finishing the swap????? are u seriouse..... that sucks.... oh does anyone know how to put a gsr motor in the crx???? word for word what i need??? and how hard it is...
Old Apr 28, 2004 | 02:36 AM
LudeEFv2.4's Avatar
My old title sucked.
Default Re: (xjun10rx)
you would be best off using the search feature for questions like this.
here is a thred i found when i searched for b18 crx
https://honda-tech.com/zerothread?id=830904
good luck with your swap and welcome to H-T
Old Apr 28, 2004 | 03:29 AM
xjun10rx's Avatar
thanx lude ..... feels good to be welcomed in...
Old Apr 28, 2004 | 08:11 AM
Mr_CRX's Avatar
you dont HAVE to get your swap passed by the referee, but its getting harder and harder to find a place that will smog an EF with a fat "DOHC VTEC" on the valve cover. They're gonna know its not stock.
Also when you get pulled over, if a cop suspects you have any modifications, he can have you pop the hood and when he sees that motor and no sticker from the BAR (Bureau of Automotive Repair) saying that you did the swap correctly and legally, he'll send you there ad you'll have to do it anyways. I say do it right from the beginning and stay legal, because its really not all that hard. Good luck!
Old Apr 28, 2004 | 08:48 AM
APEX CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xjun10rx &raquo;</TD></TR><TR><TD CLASS="quote">so i have to go get refereed once im done finishing the swap????? are u seriouse..... that sucks.... oh does anyone know how to put a gsr motor in the crx???? word for word what i need??? and how hard it is...</TD></TR></TABLE>
yup, you have to get it reff'd to get that coveted BAR sticker so when the po po's pull you over that sticker will shut them the **** up
Old Apr 29, 2004 | 09:06 PM
xjun10rx's Avatar
cant post more than 5 times a day???? who thought of that???/ well any way ..... can the crx pass with a gsr motor in it???? and what is exactly a legal swap??? do u guys know .... what do they check for???/ bump////
Old Apr 29, 2004 | 09:11 PM
SeanEF's Avatar
eat..sleep..and breath it. it is your friend
https://honda-tech.com/zerosearch
Old Apr 29, 2004 | 10:43 PM
Mr_CRX's Avatar
whoa easy with the question marks there
you can only post 5 times a day because you're still a "Trial User." This will go away in a few days.
Yes the crx can pass with a GSR engine. The engine just has to be from the same year or newer as the car it is going in. In general, it just has to be wired up as a GSR would be wired up in an actual GSR. This means either obd1 (like the 94-95 Integras) or obd2 (96+) It must also retain whatever smog equipment came on that engine. It must also use a USDM ECU specifically for that engine. (for a GSR, that means a US-spec P72 ecu)
If you have any aftermarket parts, such as an intake, or header, then when you take it to get passed at the referee, you MUST have a CARB approved intake/header.
They also check to make sure all vacuum hoses and such are running to the correct places and they do a tailpipe test to make sure it passes emissions.
There are some other things that i probably forgot, but I cant think of them right now. Try doing a search on BAR (short for Bureau of Automotive Repair) Swap, or Bar Approved or something along those lines.
Hope that helps..
Old Apr 30, 2004 | 12:41 AM
xjun10rx's Avatar
yeah man thanx... all of this is helping a ton... now do u guys know what extra parts like custom parts such as motor mounts? shift linkage? or anything that i would need to complete the swap.... do i have to do any cutting or anything? and can some one help with word for word how to actually do the swap...starting off with placing mounts thanx again this forum is the best.. people are hella cool here...
Old Apr 30, 2004 | 12:45 AM
xjun10rx's Avatar
to:scorched0 hey i cant instant message so ill write to u from here hopefully u see it...but thanx for the welcome what part of monterey county u from??... well i just purchased an 88 hf crx... cause its the lightest and i want to be faster than my gsr is... and lighter is better... well anyway... i want to swap a gsr motor into the crx... but i have an obdII motor and every one says to get obdI cause then it wont be legal... and from what people said ... i need custom mounts shift linkage.. and some spindles? thats all i know for now... any help us great...
Old May 4, 2004 | 01:45 PM
xjun10rx's Avatar
bump.....
MR. K20A
Southern California
Feb 12, 2009 10:16 PM
Kurly
Apr 1, 2008 07:06 PM
jdmracer420
Dec 3, 2004 01:41 AM
racer_X_123
14
Aug 31, 2004 03:58 PM
ironchef25
Nov 5, 2003 02:58 PM
