LS/vtec timing belt????
Old Apr 27, 2004 | 10:08 PM
JR Integra's Avatar
Default LS/vtec timing belt????
I have a 90 LS block mated with a 95 GSR head, i am using the water pump of an LS....i think. The problem is the cam gears do not line up perfectly at TDC maybe a tooth or half tooth off. Am i using the wrong timing belt possibly?
Old Apr 27, 2004 | 10:19 PM
Bspec18's Avatar
Default Re: LS/vtec timing belt???? (JR Integra)
you need a GSR water pump and GSR timing belt, u can also use a type R
Old Apr 27, 2004 | 10:23 PM
JR Integra's Avatar
Default Re: LS/vtec timing belt???? (Bspec18)
is there any marking on the water pump so i could i could identify it as a LS or GSR?????
Old Apr 28, 2004 | 06:48 AM
mmuller's Avatar
Mad Scientist
if you use ls water pump, you need ls timing belt
the non vtec water pump will say 19t in it instead of 22t for the vtec one
Old Apr 28, 2004 | 01:32 PM
Rod.'s Avatar
Default Re: LS/vtec timing belt???? (mmuller)
whatever water pump you use you get that same timing belt
Old Apr 28, 2004 | 10:09 PM
JR Integra's Avatar
Default Re: LS/vtec timing belt???? (redturbocivic)
And if the water pump and timing belt are diferent (GSR belt/LS pump) what would be the consequence???
Old Apr 28, 2004 | 10:39 PM
tinkerbell's Avatar
the belt will never fit if you use mis-matched pump/belts...
eg the GSR belt wouild be too big if you uesed a LS water pump...
and the LS belt would be too small if you used a GSR pump...
sounds like you are using a LS belt with LS pump?
Old Apr 28, 2004 | 10:46 PM
JR Integra's Avatar
Default Re: LS/vtec timing belt???? (tinkerbell)
not sure on what belt or pump i have! but your saying there is no way the belt and pump are mismatched cuz it would not fit right?? If so then what could be causing the cam gears to be a half tooth off|?
Old Apr 29, 2004 | 06:20 AM
dcb16's Avatar
what about a b16 head with c5 block, what belt would you use?
Old Apr 29, 2004 | 06:24 AM
dcb16's Avatar
is it the same thing? c5 water pump and timing belt?
Old Apr 29, 2004 | 06:54 AM
mmuller's Avatar
Mad Scientist
Default Re: LS/vtec timing belt???? (dcb16)
there is only 3 different kinds of b-series tiing belts...
b16, b18 vtecs and b18 non-vtecs
b16, cause of shorter block
all others goes by the water pump thats all
Old Apr 29, 2004 | 03:48 PM
tinkerbell's Avatar
the reason it is off is probably becasue it takes a fair bit of practice/patience to get it on and all lined up...
just keep trying
Old Apr 29, 2004 | 07:48 PM
JR Integra's Avatar
if there is no way i can get it to line up and it is a half a tooth off what should i do??? adjust both gears 1 degree +/-.
Old Apr 29, 2004 | 09:25 PM
tinkerbell's Avatar
ha ha,
all i can say is to keep trying.
make sure the cam gears are set to 0,0
and make sure the tensioner is set to full loose when you start putting the belt on...
then tighten it once the belt is fully on.
Old May 2, 2004 | 11:22 AM
JR Integra's Avatar
do you let the tension set itself or should i force it to make it tighter??
Old May 2, 2004 | 04:30 PM
tinkerbell's Avatar
no - it *should* tension itself after a few rotations, then do the tensioner bolt up....
Old May 3, 2004 | 02:20 PM
JR Integra's Avatar
ok i am going to go with a 2000 type r timing belt, water pump, and oil pump. Will this all work out with a 95 GSR head and an 90 LS block??
Old May 3, 2004 | 04:17 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JR Integra &raquo;</TD></TR><TR><TD CLASS="quote">ok i am going to go with a 2000 type r timing belt, water pump, and oil pump. Will this all work out with a 95 GSR head and an 90 LS block??</TD></TR></TABLE>
yes....
Justintegra
Apr 20, 2008 12:46 PM
ALLMOTOR CRX
Mar 5, 2007 05:43 PM
shortyz21
Nov 12, 2006 08:38 AM
lsvtechatch04
May 8, 2004 03:20 AM
vtecb20coupe
Dec 10, 2003 12:15 PM
