RSX SEATS IN A CIVIC?
Old Apr 27, 2004 | 09:00 PM
hookedonvtec's Avatar
Default RSX SEATS IN A CIVIC?
i have an 02 civic ex coupe. i know the front seats fit from the RSX but will the back seats??
Old Apr 27, 2004 | 09:51 PM
EG-B20vtec's Avatar
Default Re: RSX SEATS IN A CIVIC? (hookedonvtec)
Seats are so very important as you continue to add horsepower.
Forget the seats.
Get some power.
Old Apr 27, 2004 | 09:54 PM
gdrum's Avatar
Default Re: RSX SEATS IN A CIVIC? (EG-B20vtec)
i put rsx rears in my 95 civic, all i did was replace the metal backframes where the rsx ones were so bolt up would be the same...but then used the foam and leather covers...
so if you took the same thing with your civic and used the stock frames...a.nd covered them with the foam and leather it shoudl work....did for me
Old Apr 28, 2004 | 09:06 AM
woccowocco's Avatar
Default Re: RSX SEATS IN A CIVIC? (gdrum)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gdrum &raquo;</TD></TR><TR><TD CLASS="quote">i put rsx rears in my 95 civic, all i did was replace the metal backframes where the rsx ones were so bolt up would be the same...but then used the foam and leather covers...
so if you took the same thing with your civic and used the stock frames...a.nd covered them with the foam and leather it shoudl work....did for me</TD></TR></TABLE>
hey , you got a pic of how it looks in your car?
Old Apr 28, 2004 | 09:10 AM
snatch13's Avatar
Default Re: RSX SEATS IN A CIVIC? (woccowocco)
^^^^^ same id like to see this
Old Apr 28, 2004 | 09:27 AM
Built Beast's Avatar
Default Re: RSX SEATS IN A CIVIC? (snatch13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snatch13 &raquo;</TD></TR><TR><TD CLASS="quote">^^^^^ same id like to see this</TD></TR></TABLE>
me three...
Old Apr 28, 2004 | 08:34 PM
Default Re: RSX SEATS IN A CIVIC? (R33CIVIC)
me 4
Old Apr 28, 2004 | 09:24 PM
gdrum's Avatar
okay okay...my camera sucks nuts....but here are the best "how to" pix i could come up with.....so take it for what it is
first as you can see....both seats share the same outline/size
start by pulling the hog rings on the backside of the stock seat you pulled out of your car
and there will be more located on the inside of the seat to hold the middles of it back to define the seat cushions....
and more in the middle...
then ull see the frames are identical....the only difference is how they bolt in i.e. the rsx seats have a bolt in and the civic frames are on a swivel well you know how the civic ones are.....
then just simply take the rsx foam and place it on YOUR seat frame.....and then start by putting the leather over the foam...make sure you get the hog rings back int he middles to define the seats..pull it over and close it up...... then the seat is leather and bolts right into your car.....
Now the bottom padding doesnt fit exactly....its little shorter on the sides....i simply just set it in there and it looks fine...you really cant tell but the backs are perfect...lay down, lock in....etc like stock seats.... hopefully this works let me know....
Old Apr 28, 2004 | 09:45 PM
Shawn C's Avatar
In The Garage
bet it'd be perfect in a dc, since dc setas fit just like that in an eg
Old Apr 28, 2004 | 11:29 PM
da935oul's Avatar
looks nice
zoso
Sep 18, 2007 11:32 AM
EvenStar
Oct 24, 2006 09:47 PM
hamadiscool
Aug 13, 2006 07:55 AM
