anyone know when vtec kicks in on a stock d16z6??
Old Apr 27, 2004 | 08:52 PM
dcsports's Avatar
Default anyone know when vtec kicks in on a stock d16z6??
anyone know when vtec kicks in on a stock d16z6?? plz dont flame i tried a search couldnt find so plz no flames
Old Apr 27, 2004 | 08:54 PM
BauleyCivic's Avatar
Risky Business
Default Re: anyone know when vtec kicks in on a stock d16z6?? (dcsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcsports &raquo;</TD></TR><TR><TD CLASS="quote">anyone know when vtec kicks in on a stock d16z6?? plz dont flame i tried a search couldnt find so plz no flames</TD></TR></TABLE>
4800 - 5200 RPM depending on TPS I believe
Old Apr 27, 2004 | 08:57 PM
skip.two's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">4800 - 5200 RPM depending on TPS I believe</TD></TR></TABLE>
this is what i've read.
search harder next time.
Old Apr 27, 2004 | 09:01 PM
ARIZONA's Avatar
Default Re: anyone know when vtec kicks in on a stock d16z6?? (jL iLLuZiOnz 9)
5200 at the earliest
dcsports's Avatar
thanks for replies
Old Apr 27, 2004 | 09:25 PM
Dengar's Avatar
I was almost positive that on my z6 it was 5400. That is what the indicator light told me.
Old Apr 27, 2004 | 09:29 PM
North_Texas's Avatar
Default Re: anyone know when vtec kicks in on a stock d16z6?? (Dengar)
Yeah I also think it's between the 4800 and 5200 hundred. Something I read about the TPS system.
Old Apr 27, 2004 | 10:02 PM
xavior66's Avatar
Said it before and I'll say it again. 4,800 RPM is when VTEC will engage on a stock D16Z6.
Old Apr 27, 2004 | 10:28 PM
Risky Business
Default Re: anyone know when vtec kicks in on a stock d16z6?? (xavior66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChinChilleRKilleRs &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I also think it's between the 4800 and 5200 hundred. Something I read about the TPS system. </TD></TR></TABLE>
Old Apr 27, 2004 | 11:00 PM
Br1anPham's Avatar
Default Re: anyone know when vtec kicks in on a stock d16z6?? (BauleyCivic)
hmm according to a stock d16z6 uberdata map file that in using in my car, the exact vtec point is 5250.
Old Apr 28, 2004 | 12:28 AM
H22A EG6's Avatar
Default Re: anyone know when vtec kicks in on a stock d16z6?? (Br1anPham)
i always thought it was at 5500
cant heard the change ova
Old Apr 28, 2004 | 01:45 AM
STREETWERKZ's Avatar
Default Re: anyone know when vtec kicks in on a stock d16z6?? (H22A EG6)
another weird question........ are there any mods you can do so you can HEAR VTEC on a SOHC setup? or MINIme motor?
Old Apr 28, 2004 | 02:39 AM
ATS*Mark's Avatar
OG triple OG
Default Re: anyone know when vtec kicks in on a stock d16z6?? (STREETWERKZ)
whenever it kicks in , better ******* hold on.
Old Apr 28, 2004 | 05:29 AM
VTECisSeXY's Avatar
*insert here*
Default Re: anyone know when vtec kicks in on a stock d16z6?? (Hella_JDM)
lol
WARP SPEED AHEAD
Old Apr 28, 2004 | 05:35 AM
senpai's Avatar
4800+ rpm
13mph+
140degrees (coolant temp)
engine load (judged by intake manifold neg. pressure)
^ straight from a 1993 Civic HELM's manual
Old Apr 28, 2004 | 03:47 PM
That's real cute, but thats why I also stated that, "I also think I read that somewhere". Don't try to be funny if it's not needed.
Old Apr 28, 2004 | 04:00 PM
TeamNextGenChris's Avatar
Default Re: anyone know when vtec kicks in on a stock d16z6?? (92SIvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92SIvic &raquo;</TD></TR><TR><TD CLASS="quote">weird... mine always kicks in at 5000</TD></TR></TABLE>
is that by the stock tach?if so,they're notorious for being up to a few hundred RPMS high or low.
Chris
Old Apr 28, 2004 | 04:44 PM
ARIZONA's Avatar
Default Re: anyone know when vtec kicks in on a stock d16z6?? (TeamNextGenChris)
I still say 5200 at the earliest.
Old Apr 28, 2004 | 05:06 PM
props_honda85's Avatar
Default Re: anyone know when vtec kicks in on a stock d16z6?? (ARIZONA)
on my d16y8 vtec kicks in at 5600, but since the new VAFC II it kicks in at 5000
Old Apr 28, 2004 | 05:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ARIZONA &raquo;</TD></TR><TR><TD CLASS="quote">I still say 5200 at the earliest. </TD></TR></TABLE>
i'm not doubting you,but above the man posted info directly from the Helm manual-i'm more inclined to believe that.
like i said above,if you're basing your numbers on the stock tach,your numbers could be WAY off.on my Z6 in my EG,at WOT,my stock tach indicates about 4500 RPM when VTEC comes in.when i still had the Z6 in my coupe,it was more around 5kRPM.same motor,same ECU,different tachs.
Chris
Old Apr 28, 2004 | 05:39 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">
Ther both right, Helms says the RPMs need to be "above 4800" to activate. It doesn't neccessrily mean it will right at that point, but not before.
Old Apr 28, 2004 | 06:19 PM
Risky Business
Default Re: anyone know when vtec kicks in on a stock d16z6?? (ChinChilleRKilleRs)
That's real cute, but thats why I also stated that, "I also think I read that somewhere". Don't try to be funny if it's not needed.</TD></TR></TABLE>
I can't help it. See title.
Old Apr 28, 2004 | 06:33 PM
OBD1Kenobe's Avatar
Default Re: anyone know when vtec kicks in on a stock d16z6?? (maztur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maztur &raquo;</TD></TR><TR><TD CLASS="quote">4800+ rpm
13mph+
^ straight from a 1993 Civic HELM's manual</TD></TR></TABLE>
You are absolutely correct!!! The '94 Civic FSM published by Honda Motor Co. agrees.
It is possible for it to engage later (under extremely light engine loads), but as long as speed and temp requirements are met, it is 4800 at WOT.
Old Apr 28, 2004 | 07:01 PM
95hb's Avatar
i read somewhere that (along with the previous requirements stated above )it also varies with tps sensor input, at certain throttle inputs it engages at different points
Old Apr 28, 2004 | 07:05 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Humor is always needed. If not needed, it's welcomed.
No need to be a ***** if it's not needed.
