With $1000, what could I add to my B16A?
Old Apr 27, 2004 | 07:58 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
Default With $1000, what could I add to my B16A?
Hey guys, I'm new to this end of H-T, and I thought that maybe you could help. I'm looking to spend no more than a grand on some all-motor stuff, and I was wondering what would be the best use of my money in order to make some good power?
I've got a 1991 CRX Dx, and I've already got the usual,
1989 B16A OBD0 PR3 ECU from an 89 DA6 Teg, S1 Tranny.
I've already got the usual, a CAI, 2.5" exhaust, Header. Nothing more. I'd like to make some reliable power, and I'm not interested in Nitrous or FI at all, and I like the B16. READ: I don't want another block/head. So I'm asking what you gentlemen would do with $1000 to a near Stock 1st gen B16. Thanks guys! I appreciate it.
Old Apr 27, 2004 | 09:42 PM
SkRiBLaH's Avatar
Default Re: With $1000, what could I add to my B16A? (VashTheStampede)
bore your TB out -$100
http://www.gbronline.com/jorgep/index.html
AEBS IM -$135
http://cgi.ebay.com/ebaymotors...=WDVW
RS MAGNUM camshafts- 650
http://rsmachines.com/camshaft.html
upgraded valvetrain - the rest of the money and maby + 100 bux.
thats what i would do.
Old Apr 28, 2004 | 07:33 AM
nickgmiller04's Avatar
cams, cam gears, matching valvetrain + hondata. maybe more than 1k, but i think hondata would be worth it
Old Apr 28, 2004 | 07:40 AM
Rollo Lawson's Avatar
if you are not going to exceed 8400rpm, then, obtain these parts
p30 intake manifold (get it ported)-$90 total
lightest flywheel you can find-$200
itr cams-$250
mill the head-$40
cams gears-$200
1g talon fuel pump-$20 (roughly 155LPH)
used hondata-$225
tuning-$150
$1175. its a bit over your budget, but, its a good starting point.
Old Apr 28, 2004 | 08:31 AM
yaaj1320's Avatar
Default Re: (B16C1)
i got a turbo kit going for $1000...i got 251whp on 10lbs...untuned..on a b16a3 delsol..if ur interested call me at 615-491-1656...
Old Apr 28, 2004 | 08:43 AM
CHEETAH's Avatar
upgrade the valvetrain and put in some more aggresive camshafts with adj camgears, reprogram ECU then hit the dyno and have someone tune it. that'll prolyl be the best money spent.
I can do the ECU reprogramming part all I usually need is the list of mods. I prolly have some used cams and vlavetrian too, if you decide to go this path, feel free to PM me.
Greg
Old Apr 28, 2004 | 11:45 AM
Archidictus's Avatar
Unceasing Measure
Why not a B20 block? Laziness or something else .
Old Apr 28, 2004 | 12:09 PM
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Why not a B20 block? Laziness or something else .</TD></TR></TABLE>
You find a B20 block around Wooster, and I'll get my lazy *** over there to get it.
Thanks for the replies guys!!
Still looking for ideas...
Old Apr 28, 2004 | 12:10 PM
roadawg's Avatar
type r cams, VAFC, dyno
Old Apr 28, 2004 | 03:48 PM
B20/VTEC Buildup. Mwahahaha..
That's the goal now.
It shall conquer all.
Old Apr 28, 2004 | 04:19 PM
KiLLa CaM 06's Avatar
Default Re: (VashTheStampede)
tech43 ls stoker piston kit
Old Apr 28, 2004 | 06:29 PM
FATBOYeg6's Avatar
Default Re: (KiLLa CaM 06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KiLLa CaM 06 &raquo;</TD></TR><TR><TD CLASS="quote">tech43 ls stoker piston kit</TD></TR></TABLE>
with 85mm pistons, it is 2020cc
Old Apr 28, 2004 | 06:44 PM
Broken Gearbox's Avatar
Default Re: (ninefivehatch)
AEBS Intake Manifold w/ Hondata Gasket
Bored TB
ITR Cams
VAFC
Then spend the rest of the money getting it dyno tuned.
Also replacing some gaskets would be a good idea too, cause it is a 1989 motor.
Good Luck.
Old Apr 28, 2004 | 07:27 PM
Default Re: (2.2L)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2L &raquo;</TD></TR><TR><TD CLASS="quote">AEBS Intake Manifold w/ Hondata Gasket
Bored TB
ITR Cams
VAFC
Good Luck. </TD></TR></TABLE>
That's a good idea! I've heard that the CTR cams are better... is that true? If so, should I upgrade the valvetrain? Skunk2 maybe?
Old Apr 28, 2004 | 07:40 PM
I think the stock valvetrain should be fine.
What do you guys think?
Old Apr 28, 2004 | 07:50 PM
Can you guys give me an estimate for power wise? Will that pick up 20hp?
Old Apr 28, 2004 | 08:05 PM
duckmanEG's Avatar
Sexy Cheese Cake
Default Re: (2.2L)
aebs satin finish dont need the bling polish one,
bored tb from that guy on this site,
then the cam part is up to you but rlz's stage 2 i heard are good like the toda b in the mid then like jun 3 up top, also some buddy clubs, rm's, dynamic
sum valve springs and retainers and cam gears upgrade. might be a bit more but then should be decent power
Old Apr 28, 2004 | 08:12 PM
Mr.E.G.'s Avatar
all i know is that the spoon stroker kit only costs 1500 dollars. i'm more a fan of destroking but you cant argue with results. it comes with crank pistons rods all the bearings and accessories, and an ecu that is tuned to that setup.
Old Apr 28, 2004 | 08:21 PM
boostEG6's Avatar
^ If your going to add some new cams I would think getting the valvetrain upgraded would be a good idea
Old Apr 28, 2004 | 08:23 PM
boostEG6's Avatar
oh ya if your on a $1K budget. Get some cam gears, vafc , tuning and free up your exhaust a bit.
Old Apr 29, 2004 | 05:51 AM
roadawg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VashTheStampede &raquo;</TD></TR><TR><TD CLASS="quote">
That's a good idea! I've heard that the CTR cams are better... is that true? If so, should I upgrade the valvetrain? Skunk2 maybe?</TD></TR></TABLE>
I recently puy CTR cams in my car and upgraded the valvetrain to portflow inners so I can rev to 8500 to get the most out of the cams. It depends if you want to keep your stock valvetrain, but if you want to rev to 8500 or so its not a bad idea tp upgrade your springs, portlfow inners are only $80 shipped to your door.
EJ8 Jay-B
35
Dec 22, 2010 07:55 PM
Not2farFromtypeR
Feb 4, 2009 06:48 AM
romero4
Oct 12, 2006 05:20 AM
b16a27
Jan 28, 2005 07:53 AM
iridebiketrials
Jan 20, 2004 11:26 AM
