My BOLTS are popping out...HELP!!..JDM HEADER & CARSOUND CAT
Old Nov 1, 2001 | 10:57 AM
hYpE-R-29's Avatar
Default My BOLTS are popping out...HELP!!..JDM HEADER & CARSOUND CAT
i have JDM headers and a 2.5' carsound cat, i connected those 2 with grade 8 bolts that are 3 1/2 inch...i also put the stock springs on there so the tension can be less...but now i hear them squeaking and they are making noises now...what kind of method did u guys use to bolts ur header JDm and CAt...need help fast!!
Old Nov 1, 2001 | 11:13 AM
sackdz's Avatar
Default Re: My BOLTS are popping out...HELP!!..JDM HEADER & CARSOUND CAT (hYpE-R-29)
The stock bolts wouldn't seal my test pipe to the donut gasket very well. The "foot" hit the flange on the header before the were adaquately tightened down. I just bought plain old bolts, and compressed the spring quite a bit, but it is coming loose again. I would also like to hear how people have dealt with this.
Old Nov 1, 2001 | 11:35 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
Default Re: My BOLTS are popping out...HELP!!..JDM HEADER & CARSOUND CAT (sackdz)
There're some ways that constuction industry use to prevent bolt from getting loose. I dunno if they can be applied to cars tho.
One way is to tag weld the nut after tightening.
Another way is to damage the thread after tightening.
In case you need to remove those bolts in the future, just cut them off.
[Modified by Wai, 12:36 PM 11/1/2001]
Old Nov 1, 2001 | 11:45 AM
Big Phat R's Avatar
You could also try high-temp thread lock.
Old Nov 1, 2001 | 12:00 PM
smeister's Avatar
Some red loctite maybe? I used them on my swaybar install heheh
Old Nov 1, 2001 | 01:11 PM
SMSP's Avatar
I believe the spec is 16 lb-ft but you can tighten them snug but just make sure you don't coil bind the springs. Your bolt length is correct. But 2 extra nut and just double nut the bolts. My kit consists of the (2) 90mm bolts with 4 nuts and 2 washers and (3) 10mm x 40mm bolts with nuts for the b pipe. Double nutting is better than a lock nut since they are a lot easier to take off, time wise.
Old Nov 1, 2001 | 01:47 PM
onyx00's Avatar
Default Re: My BOLTS are popping out...HELP!!..JDM HEADER & CARSOUND CAT (SMSP)
I would make sure you know what is making the squeaking sound.
I have the SAME EXACT PROBLEM, however, it turned out my O2 sensor ont he carsound cat. was rubbing the upper metal shield attached to the car. That was causing the squeaking.
So I would look under the car and make sure you know where the squeaking is actually comming from.
Old Nov 1, 2001 | 02:01 PM
sackdz's Avatar
****, I put anti sieze on the damn things so that they wouldn't be hard to get off. Ha, that's probably why they're loosening.
Old Nov 1, 2001 | 02:14 PM
hYpE-R-29's Avatar
Default Re: My BOLTS are popping out...HELP!!..JDM HEADER & CARSOUND CAT (onyx00)
Im sure this is where the squeaking sound is coming from because it happeded to me before and i went under the car and tightened everything...on each nut i have 2 sets of washers, lock nuts and a big washer so the spring can compress against it...it looks exactly like the stock setup.....i also have 2 nuts screwed against every bolt so its tight...but still i hear the damn thing...i asked around by just using a regular nut and but...but i heard that it has to flex...and if it doesnt it make crack off...im gonna go under the car soon as soon as it coold down...i dont wanna get burned.....ANY OTHER ADVICE on what i should use or do?...is this a common problem also??
Old Nov 1, 2001 | 03:26 PM
onyx00's Avatar
Hmm, I dunno, make sure nothing is rubbing. When you are done there give the pipes a good tug and see if you can replicate the sound.
I am using the same setup as you will all my bolts replaced (no stock bolts being used).
TypeRmsm has some good tips/suggestions on bolt sizes, etc to replace the stock ones. I will toss him an IM and see if he can post reccomendations.
Old Nov 1, 2001 | 04:08 PM
d8168055's Avatar
Use the 4" (or 4.5", i forgot) ones... they are longer, so u have more thread to play with... they worked fine for mine...
Old Nov 1, 2001 | 04:15 PM
hYpE-R-29's Avatar
Default Re: My BOLTS are popping out...HELP!!..JDM HEADER & CARSOUND CAT (d8168055)
did u guys use the stock springs that were attached to the stock bolts?...
Old Nov 1, 2001 | 07:06 PM
Mike M's Avatar
Founding Member
90mm Length bolt Grade 8 12mm bolt into 2 fender washers then stock springs through cat then through header, followed by flat washer, lock washer and a nut, Tighten down until the spring is compressed to about 1/8-1/16 of an inch between each coil. When finished install another nut which will keep the other from loosening
Old Nov 2, 2001 | 08:17 AM
hYpE-R-29's Avatar
Default Re: My BOLTS are popping out...HELP!!..JDM HEADER & CARSOUND CAT (TypeRmsm)
Hey Mike..i bought the Carsound Cat from you...but the nut keeps on popping out...you wouldnt happen to have a picture on how the setup is suppose to look like?...this would be very helpful...also i as going to go buy some kind of lubricant that seals the thread of the bolt...its called something 271???...my setup is grade 8 bolt, then flat washer, then stock spring, then another flat washer so the spring can be compressed against it...then on the header side i have 2 small washers, 1 lock nut, then 2 regular nuts...but damn thing keeps on popping out..post a pic if u got one..thanks..
Old Nov 2, 2001 | 08:35 AM
Mike M's Avatar
Founding Member
Sorry no pics, just follow the instructions i posted above, The nut wont come loose if you put a 2nd one after it.. You can also try some loctite, but not needed and i doubt it will last with the high temps
Old Nov 2, 2001 | 12:08 PM
d8168055's Avatar
wow... u got more bolts than i do... i dont have any problems w/ mine tho... i did exactly as mike described... and it works fine...
Old Nov 2, 2001 | 03:25 PM
hYpE-R-29's Avatar
im just plain stupid....this is what im doing...got a 3 1/2 grade 8 bolt...stuck a flat washer threw it..then stock spring....then stuck it in threw the cat side and other end popped out of the header...then on the header side added another flat washer, then lock nut..then 2 nuts....hope this works....what u guys think...am i good to go?
Old Nov 2, 2001 | 03:41 PM
Mike M's Avatar
Founding Member
How tight did you put it? Should have the spacing in the coils as i explained above
Old Nov 2, 2001 | 03:49 PM
sackdz's Avatar
Doesn't the spring go between the cat flange and the header flange?
Old Nov 2, 2001 | 04:01 PM
hYpE-R-29's Avatar
i have some space...so should it be fine?...
Old Nov 2, 2001 | 04:15 PM
Mike M's Avatar
Founding Member
No, my first post describes how it should be
Old Nov 2, 2001 | 07:12 PM
hYpE-R-29's Avatar
the springs are pretty well coiled up and very tite....
Old Nov 2, 2001 | 07:14 PM
hYpE-R-29's Avatar
i think i need help...any shops u may reccommend here in the bay area?...
94B18B1Teg
Mar 15, 2004 11:05 AM
SleepnCiViC
Dec 8, 2003 09:06 PM
Aaron M
Apr 7, 2003 08:03 AM
NSX Bob
Oct 17, 2001 03:55 PM
