(obd1) gsr is hesitating, bogging and puttering
Old Apr 27, 2004 | 07:23 PM
sal_blkej2's Avatar
Default (obd1) gsr is hesitating, bogging and puttering
just yesterday when the i took the car out for a drive i noticed that it was idling like crap and i could barely get it out off the driveway. once i did it started to hesitate, bog and putter all at once. a lil bit of everything. i checked the harness, spark plugs and cap, nothing was wrong. so i went to the fuel rail and checked my injectors. i did notice the one on cylinder #2 wasnt spitting out as much as the others were so i went to the local autozone to get some fuel injector cleaner and put it in as directed to. still the same problem. anyone ever has this problem or know what could be wrong? i was wondering if i could try and replace that #2 injector with a d-series injector but not sure if they would fit. i think their all 240cc correct? just unsure if their interchangable. i would sure appreciate some help cuz i need my car for work and to take my son to school.
*tried a search but nothing similar to this with all 3 problems.
thanks, Sal
Old Apr 27, 2004 | 07:32 PM
sal_blkej2's Avatar
Default Re: (obd1) gsr is hesitating, bogging and puttering (sal_blkej2)
i guess i'll try the fuel filter and pcv valve next
Old Apr 27, 2004 | 10:34 PM
sal_blkej2's Avatar
ttt
Old Apr 27, 2004 | 10:40 PM
Sack Master's Avatar
There are too many things it could be. Could be something simple like a spark plug wire. Could be something a little more complex. I had something similar to that happen in mine and it was nothing more than a plug wire. A friend had something similar to that and his o2 sensor was just being silly. Replaced the o2 and has ran fine since. Just a couple ideas for you. But it's a good idea to replace the fuel filter and pcv valve. Good luck with that.
Old Apr 28, 2004 | 04:53 AM
sal_blkej2's Avatar
Default Re: (obd1) gsr is hesitating, bogging and puttering (Sack Master)
well i checked each spark plug wire and their all getting spark plus their only 2 months old. i did drive the car this morning and notice it started doing it once it got to its regular running temp. approximately 5-6 miles. its starting to **** me off. when it happens, it sounds like crap and like i'm only running on 2-3 cylinders. i'll check some more **** once i get off of work. thanks, Sal
88 EF Hatch
Sep 25, 2009 11:57 AM
IntegraG2
May 8, 2009 08:26 AM
uses0ap
May 1, 2009 07:30 AM
hlee5363
Oct 6, 2005 07:20 AM
