power door lock problem
Old Apr 27, 2004 | 07:04 PM
switching5's Avatar
Default power door lock problem
sorry if this is not the right board but im a newbie here. Anyways my power door locks doesnt work and i brough it to honda. They said we cant fix it because you have an AFTERMARKET radio. In order to fix it i need the old stock radio. I just got the radio installed around last july and the power locks broke around Febuary. Is it really the problem or should i go somewhere else and get it repaired?
civic 97 lx 4dr
Old Apr 27, 2004 | 07:18 PM
scorched0's Avatar
Default Re: power door lock problem (switching5)
that's bull. We do those vehicles all the time without problems with the power door locks. also btw, if you have a 97 civic, you should probably be posting in the "EK" section...that's the appropriate one for your generation of vehicle.
Old Apr 27, 2004 | 07:40 PM
APEX CRX's Avatar
thats nuts, never heard of an aftermarket radio aftecting power door locks. First off did you check the fuse for the power door locks?
Old Apr 27, 2004 | 07:55 PM
SuperSteve's Avatar
New User
25 Year Member
Default Re: power door lock problem (APEX CRX)
From 96 to 98 Honda placed the keyless module in the factory radios. You need to keep your factory radio powered up and the green plug plugged in even when you add an aftermarket radio.
Old Apr 27, 2004 | 07:58 PM
APEX CRX's Avatar
Default Re: power door lock problem (SuperSteve)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSteve &raquo;</TD></TR><TR><TD CLASS="quote">From 96 to 98 Honda placed the keyless module in the factory radios. You need to keep your factory radio powered up and the green plug plugged in even when you add an aftermarket radio.</TD></TR></TABLE>
but why did it take so long to affect his locks then?
Old Apr 27, 2004 | 08:00 PM
scorched0's Avatar
There is a harness which removes that problem....though sometimes the stock radio is just shoved behind the new one....might want to pull out the new radio and see what the wiring looks like behind there...
Old Apr 27, 2004 | 08:03 PM
APEX CRX's Avatar
Default Re: power door lock problem (scorched0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scorched0 &raquo;</TD></TR><TR><TD CLASS="quote">There is a harness which removes that problem....though sometimes the stock radio is just shoved behind the new one....might want to pull out the new radio and see what the wiring looks like behind there...</TD></TR></TABLE>
that sounds more reasonable, plus I did not see that he has a 97 Civic. I thought he was talking in general of stock Honda radios
Old Apr 27, 2004 | 08:09 PM
SuperSteve's Avatar
New User
25 Year Member
It should only affect the keyless part. It should not disturb the door switch at all. Have you gone through it and checked your fuses both under the hood and kick?
Old Apr 28, 2004 | 06:04 AM
switching5's Avatar
i checked a few fuses but im not sure which to look at so i looked at a few. Everything seems to be good. So what do i do? I cant really get old one radio so its stuck like this? BTW im getting it fixed so i could get my keyless alarm too
Old Apr 28, 2004 | 06:14 AM
switching5's Avatar
btw if it makes a difference i have a pioneer DEH 1500..i dont know what harness i have but i just let best buy install it for free
Old Apr 29, 2004 | 04:49 PM
scorched0's Avatar
My guess would be that they just shoved the stock radio behind the pioneer when they installed it to preserve the locks, but the stock radio has now gone out and killed the locking system it was attached to. Pull out the pioneer with the radio keys and check behind it...
Old Apr 29, 2004 | 10:37 PM
switching5's Avatar
when i check behind it what do i do??
Old Apr 29, 2004 | 10:42 PM
YumVTEC's Avatar
this is in the EF forum, why?
Old May 2, 2004 | 09:09 PM
scorched0's Avatar
Default Re: power door lock problem (YumGTR)
heh...check to see if the stock radio is behind it...if it is, then you can get it tested to see if its functional. If it is still functional, then you can rule out the radio as being the cause of the problem.
Syndacate
18
Nov 25, 2022 06:17 PM
rcm
Sep 23, 2008 07:35 PM
BSIXTEENSOFAST
Acura TL, RL & ZDX
Aug 8, 2005 07:46 AM
Inaniac
Jan 4, 2002 02:16 PM
