Car pulls to the right on gas?
Old Apr 27, 2004 | 05:16 PM
CWBETB's Avatar
Default Car pulls to the right on gas?
Anyone know why my car would be pulling hard to the right when i give it gas? If I lay off the gas it goes straight so I dont think its my allignment. Would a bad Axle cause this? Its like I have tourque steer but I dont remember it being this bad, its even if I give it a slight amount of gas? This is on a 90 Civic with a 90 Si trans/ZC engine. Any advice will be helpful!
Old Apr 27, 2004 | 05:35 PM
MENACE's Avatar
Default Re: Car pulls to the right on gas? (CWBETB)
Its called Torqe Steer its becuase the Si tranny uses a Short and a long axle. The Right side of the car has the shorter axle. The Car pulls to that side because the power is more easly tranfered to the shorter axle.
Old Apr 27, 2004 | 05:36 PM
infinatenexus's Avatar
VtEcK PoWa
Old Apr 28, 2004 | 04:07 AM
CWBETB's Avatar
I am even getting it when I give it a slight amount of gas though. I also had my car since 96 and never felt this before
Old Apr 28, 2004 | 04:54 AM
MENACE's Avatar
Well Check your tire Pressure. Also when my Drivers side Wheel bearing was starting to go bad i felt it alot more, Because there was more drag on that wheel. So basicaly check anything that might cause more drag on the opposite side of the car. Like Tire pressure on both sides, Wheel bearing, and make sure your brakes arent gettin stuck. Thats all i can think of now. Check those then let us know.
Old Apr 28, 2004 | 05:28 AM
MightyMouseTech's Avatar
Default Re: Car pulls to the right on gas? (MENACE)
I would be checking your suspension closely, It can be:
-alignment
-radius rod bushings
-lower control arm inner bushings
-lower ball joints
-upper ball joints
-loose tie rod
etc etc etc. It is impossible to tell via a forum, you are going to have to lift it up and check it out.
scubacamper
Nov 20, 2015 09:25 PM
skateboard_ej8
Oct 7, 2008 11:50 AM
redDAinteg
Feb 17, 2007 07:56 PM
CWBETB
Apr 25, 2004 04:07 PM
Ronnie00si
Apr 20, 2004 02:45 PM
