Burning Oil Vol2: Compression Test Results
Old Apr 27, 2004 | 05:14 PM
98cwitr's Avatar
Default Burning Oil Vol2: Compression Test Results
Results:
#1: 230
#2: first try: 210 2nd try: 220 3rd try: 220
#3: first try: 230 2nd try: 235
#4: 240
so im guessing everything is fine with the compression...will get a valve adj. and leakdown test soon...
Old Apr 27, 2004 | 05:44 PM
bubbakush's Avatar
Default Re: Burning Oil Vol2: Compression Test Results (98cwitr)
Interesting, keep us updated. I too have burnt a qt of oil but i have been pushing my itr hard
Old Apr 27, 2004 | 06:29 PM
RTW DC2R's Avatar
those numbers arent too bad. do the leak down and see what you get.
Old Apr 27, 2004 | 06:36 PM
98cwitr's Avatar
Default Re: Burning Oil Vol2: Compression Test Results (bubbakush)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bubbakush &raquo;</TD></TR><TR><TD CLASS="quote">Interesting, keep us updated. I too have burnt a qt of oil but i have been pushing my itr hard</TD></TR></TABLE>
thats the thing...i rarely push the R...well i drive kinda 'aggressively' but shift around 4,500-5,000 rpms through 1st-3rd gear. I hit VTEC for the first time in two weeks today, and it was from 5,500rpms to 5,800 rpms
Old Apr 28, 2004 | 01:06 AM
Ryuji's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98cwitr &raquo;</TD></TR><TR><TD CLASS="quote">
thats the thing...i rarely push the R...well i drive kinda 'aggressively' but shift around 4,500-5,000 rpms through 1st-3rd gear. I hit VTEC for the first time in two weeks today, and it was from 5,500rpms to 5,800 rpms </TD></TR></TABLE>
Then why have you bought it ?
Old Apr 28, 2004 | 04:37 AM
Philly_NBP_R's Avatar
Default Re: Burning Oil Vol2: Compression Test Results (Ryuji)
yeah, seriously.... I try to hit vtec on a daily basis! Makes me feel better about everything
Old Apr 28, 2004 | 04:56 AM
magic hat #9's Avatar
Default Re: Burning Oil Vol2: Compression Test Results (Philly_NBP_R)
are you sure you're burning oil? maybe you're leaking oil. any blue clouds coming from the tailpipe? i was leaking half a quart every 100 miles; it turned out the o-ring on the air breather box was the source. check your motor top to bottom and look for fresh oil; clean the motor and recheck if it's hard to tell.
Old Apr 28, 2004 | 10:16 AM
98cwitr's Avatar
Default Re: Burning Oil Vol2: Compression Test Results (magic hat #9)
no, there is no bluish white smoke...only black Ive checked for leaks and there are none.
Old Apr 28, 2004 | 12:46 PM
emotionisdead's Avatar
Very Emergency!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R &raquo;</TD></TR><TR><TD CLASS="quote">yeah, seriously.... I try to hit vtec on a daily basis! Makes me feel better about everything </TD></TR></TABLE>
word up!! vtec is the ****, plus it is heathly for the motor to blow all the carbon and **** out if you have been putin around alot. i used to drive my R like ****** grandma, but now i hit vtec at least once a day and it seems to have a little more pep in it's step after i rev it out.
Old Apr 28, 2004 | 12:47 PM
Chris N's Avatar
Default Re: Burning Oil Vol2: Compression Test Results (SpoonDC2R)
Leakdown will tell much more.
Old Apr 28, 2004 | 03:42 PM
Austin's Avatar
Default Re: Burning Oil Vol2: Compression Test Results (Chris N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">Leakdown will tell much more.</TD></TR></TABLE>
No it wont...if it's the oil rings that are haveing issues they're below the compression rings, so you'll have great compression, and the leak down will look great, however the oil rings may be worn out and leaving oil on the cylinder walls...hence the reason that you're burning oil....
Austin
Old Apr 28, 2004 | 08:00 PM
RTW DC2R's Avatar
Default Re: Burning Oil Vol2: Compression Test Results (Austin)
yeah but the leakdown will narrow it down. if the leakdown comes back good, then chances are its just the oil rings.
Old Apr 29, 2004 | 08:06 AM
98cwitr's Avatar
Default Re: Burning Oil Vol2: Compression Test Results (RTW DC2)
anyone ever had this done...how much would replacing the oil rings set me back?
Old Apr 29, 2004 | 12:26 PM
WAFFLES's Avatar
You have a 20psi spread between 2 of your cylinders. Honda only allows 20-25psi difference. That could be your problem right there.
Old Apr 29, 2004 | 12:29 PM
irev210's Avatar
Default Re: Burning Oil Vol2: Compression Test Results (WAFFLES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES &raquo;</TD></TR><TR><TD CLASS="quote">You have a 20psi spread between 2 of your cylinders. Honda only allows 20-25psi difference. That could be your problem right there.</TD></TR></TABLE>
Im not laughing but im really laughing
care to explain that theory?
Old Apr 30, 2004 | 09:13 AM
98cwitr's Avatar
um ok...according to your theory/honda everthing is ok??? You're confusing me
oh an BTW, ive noticed that my oil gets dirty pretty quick, could that mean anything? This **** didnt start until after I installed my header and cat
Old Apr 30, 2004 | 09:37 AM
Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austin &raquo;</TD></TR><TR><TD CLASS="quote">
Austin</TD></TR></TABLE>
My thoughts and EXPIRENCE exatcly.
If leakdown=teh bad then goto valves
If leakdown=teh good then goto oil rings
Black smoke? ONLY at high RPM? Oil dots on bumper? COMPRESSION RINGS.
Old Apr 30, 2004 | 09:39 AM
Chris's Avatar
oh an BTW, ive noticed that my oil gets dirty pretty quick, could that mean anything? This **** didnt start until after I installed my header and cat </TD></TR></TABLE>
also happened to me after I put the JDM header on. coincidence I think.
Old Apr 30, 2004 | 09:40 AM
Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98cwitr &raquo;</TD></TR><TR><TD CLASS="quote">anyone ever had this done...how much would replacing the oil rings set me back?</TD></TR></TABLE>
I had my bottom end balanced, blueprinted and .025 CTR pistons with new bearings and rings installed for $1300...
I did all the removal and re-install
Old Apr 30, 2004 | 09:42 AM
hypa's Avatar
Default Re: Burning Oil Vol2: Compression Test Results (Chris)
stupid question, but have you changed your PCV lately?
Old May 1, 2004 | 12:34 PM
98cwitr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris &raquo;</TD></TR><TR><TD CLASS="quote">
I did all the removal and re-install</TD></TR></TABLE>
well Chris, you're just the ****...ive never done any serious head/motor work before
hypa: no I havent replaced my PCV valve (which I have a catch can hooked up too and its not got any oil in it, just the line)
jcskyhigh
Jul 25, 2007 01:24 PM
Fat Chick Magnet
Nov 22, 2006 09:52 PM
nekoabandoned
Jul 24, 2006 03:39 PM
mafay2
Nov 11, 2004 07:34 PM
CRX SiR T
Nov 24, 2003 12:49 PM
