eg/ek lca's?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FkingSUV »</TD></TR><TR><TD CLASS="quote">are the ek and eg lca's the same? interchangable?
looking to get a cheap set, and all they have listed on ebay are ek...?</TD></TR></TABLE>
no
no
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EricUSC »</TD></TR><TR><TD CLASS="quote">No, they are not. I believe that 94-01 Integra and 92-95 Civic LCAs are interchangeable.</TD></TR></TABLE>
you are correct
You can use them either way. The ek lca is narrower where the shock connects. You can put eg lca's into an ek but you have to use shocks designed for an eg. You can put ek lca's into an eg but you will have to use spacers in the lower shock fork.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fishnfst »</TD></TR><TR><TD CLASS="quote">You can use them either way. The ek lca is narrower where the shock connects. You can put eg lca's into an ek but you have to use shocks designed for an eg. You can put ek lca's into an eg but you will have to use spacers in the lower shock fork.</TD></TR></TABLE>
