p54 ac bracket is from del sol b16 and CRV...?
Old Apr 27, 2004 | 04:17 PM
wizzards581's Avatar
Default p54 ac bracket is from del sol b16 and CRV...?
again to make this clear. looking for jus del sol b16 is to rare. crv is also the same?
Old Apr 27, 2004 | 09:46 PM
Default Re: p54 ac bracket is from del sol b16 and CRV...? (wizzards581)
bump?
Old Apr 27, 2004 | 10:05 PM
skip.two's Avatar
what the hell is up with people not searching recently. p54 is from the del sol. been here for almost 3 years. amazing that you dont know how to search yet.
Old Apr 28, 2004 | 04:13 PM
Default Re: p54 ac bracket is from del sol b16 and CRV...? (jL iLLuZiOnz 9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 &raquo;</TD></TR><TR><TD CLASS="quote">what the hell is up with people not searching recently. p54 is from the del sol. been here for almost 3 years. amazing that you dont know how to search yet.</TD></TR></TABLE>
yes i know. its posted above. i jus wanted to make sure for the last time that crv and delsol b16 uses the same ac bracket. because if so im going straight to crv instead of delsol b16s.
Old Apr 29, 2004 | 04:58 PM
methos713's Avatar
you want a p54 a/c bracket...I have one that's not in use...well i never got to use it. But if you are still looking for one let me know.
Old Apr 29, 2004 | 05:31 PM
Beatkidd's Avatar
Default Re: p54 ac bracket is from del sol b16 and CRV...? (methos713)
yes p54 is from a del slow
and i think the crv bracket has p7h stamped on it either way im using a crv bracket and it worked fine B16 into eg
Old Apr 29, 2004 | 06:47 PM
NickFury's Avatar
Default Re: p54 ac bracket is from del sol b16 and CRV...? (Beatkidd)
you can use either a del sol p54 or a crv p7h (i think that was the stampinh..but it was like that.) a/c bracket to compromise a D's compressor on a B's motor..i know i have used both of them...
Old Apr 29, 2004 | 07:06 PM
Default Re: p54 ac bracket is from del sol b16 and CRV...? (NickFury)
so crv will hold d series ac compressor all 4 bolts?
some guys on here had call honda and said both same part#... so jus making sure again..
Old Apr 29, 2004 | 07:29 PM
ARIZONA's Avatar
yes, all 4 bolts.
Old Apr 29, 2004 | 07:48 PM
Hybrid96EK's Avatar
Why not get a JDM ITR one? Its lightweight and will work just as well as the P54.
Old Apr 29, 2004 | 08:06 PM
Default Re: p54 ac bracket is from del sol b16 and CRV...? (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">Why not get a JDM ITR one? Its lightweight and will work just as well as the P54.</TD></TR></TABLE>
sounds interesting... how much less? so integra and civics in japan uses all same compressor? j/w... how much for one thougH?and where to get one.
Old Apr 29, 2004 | 08:36 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wizzards581 &raquo;</TD></TR><TR><TD CLASS="quote">
sounds interesting... how much less? so integra and civics in japan uses all same compressor? j/w... how much for one thougH?and where to get one.</TD></TR></TABLE>
I am not 100% sure on the weight savings, but I know its quite a bit lighter then the stock cast unit. I don't know about what compressors are used in japan... I think they use the same as the US. You can get one from http://www.jhpusa.com... They run $120 each, which is slightly more then you will pay for a new P54 bracket.
Old Apr 30, 2004 | 04:23 PM
my bro works for toyota and they called honda earlier.. its 130 something.. with toyotas discount. someone close by is selling for 120 pick up...
i cant find the ac bracket on the page... if you can help me?
Old Apr 30, 2004 | 05:21 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wizzards581 &raquo;</TD></TR><TR><TD CLASS="quote">my bro works for toyota and they called honda earlier.. its 130 something.. with toyotas discount. someone close by is selling for 120 pick up...
i cant find the ac bracket on the page... if you can help me? </TD></TR></TABLE>
I work for Toyota too, they aren't giving you any discount if thats what they quoted you. Its not on the page, you have to email them about it.
Old May 1, 2004 | 12:02 PM
well alot of my friends bought it from honda for about 150-160 themselves. my bro can get it out the door for 130.. its not bad but still.. couple dollars saves.
Old May 1, 2004 | 12:30 PM
miahmouse's Avatar
http://www.hondaautomotivepart...81%29
#1 $100.82
Old May 1, 2004 | 03:00 PM
Default Re: p54 ac bracket is from del sol b16 and CRV...? (miahmouse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miahmouse &raquo;</TD></TR><TR><TD CLASS="quote">http://www.hondaautomotivepart...81%29
#1 $100.82</TD></TR></TABLE>
thanks man.. haha...
Old May 1, 2004 | 05:11 PM
Hybrid96EK's Avatar
thanks man.. haha...</TD></TR></TABLE>
I just ordered my alum Type R one for $120 shipped with tax. Whatever floats your boat though. I figured an extra $5 or so was worth the 5lbs it saves.
Old May 1, 2004 | 10:27 PM
its going 135 for me...
initialR
Aug 24, 2010 12:30 PM
XkjeldorX
Jun 7, 2006 06:09 PM
Scorchin Civic
Texas -OK -LA (Sales)
Jun 5, 2006 03:53 PM
Dorikamu
Jun 10, 2002 08:08 PM
94HybridEX
May 13, 2002 12:37 AM
