Gotta a newbie question for all you kids with ITR experiance
OK, I have been driving my 97 ITR around for a couple of weeks now and I noticed sometime when I come to a stop it does not return to normal idea and instead idles at 1000 to 1800 about. I was just wondering if this was normal.
The car only has 5000 miles and the only mod is a cat-back mugen exhaust.
Thanks!
Thanks!
Do you have your lights or A/C on at that time? Idle between 800-1200 is normal depending on the conditions...
...although at startup you may idle as high as 1500-1600.
[Modified by Darth VadeR, 1:35 PM 11/1/2001]
my '98 does the same thing when i come to a stop after hitting the brakes pretty hard. dealer could not replicate problem and said they had no thoughts.
Well, I don't have an ITR but this seems related.
Turn on your motor and let the car idle in park. Then press your brake pedal as *hard* as you can. Look at the tach, it goes buck-crazy... well for my car at least
its normal , dont worry about it, all of our cars do it. Man, i thought i had low miles on my 97, i just reached 15,000
Thanks, I was worried, but it is a Honda so I am sure it does the weird idle for a reason.
Yeah, I was excited when I found a type R with so few miles.
http://community.webshots.com/user/x_1fastgti_x
If that works (crossed fingures) you can see a picture of my R and my old GTi.
Luckily i just came home from revving my car today!
It normally idles at around 1500rpm's on mine (brand new 145kilometres on it so far).
And i also noticed today that presses the brake pedal MINORILY affects the tachometer. Only to like 1000-2000rpms at most.
*after edit*---
And is it just me or am i abit of a paranoid softy. When i was revving the car i would go to only about 4000rpm's and the car is SOOO FCKING LOUD i just could'nt go on. Maybe it's cause i was doing it in a garage, maybe it was cause the windows were down or maybe it was cause i'm a softy
I can't imagine a car being any louder it'd be ridiculous. I tried to sleep with the engine running and the bassy feeling just kept me from sleeping. Too loud, too much rumbling and mumbling and vibrations............ i love it
[Modified by lordastro, 8:20 PM 11/2/2001]
*after edit*---
I notice my car does that, after i pull off of the freeway, and im stopped at the light.. not all the time though
Really? Thats strange then.
Hmm..
I start up the engine, it moves around abit below 1000rpms. And then afew seconds later it creeps itself up to 1500rpm's.
Should i worry about this? This ain't at the lights or anything, it's just in my garage.
Hmm..
dude i wouldnt buy a 97' that only has 5000 miles on it...there is no way that car was broken in properly...i meann the original owner did not drive it enough...it might sound wierd but i think a 97' b18c5 needs more wear then 5k in 4 years.
Hmm..
Hmm..
It is normal for the engine to idle at 1500rpm during the warm-up process. I simply stated that it is abnormal once the car HAS been warmed up
The things the effect idle...
-engine vacuum
-electrical load detector (headlights/heater fan/cooling fan/etc.)
-"power steering fluid" pressure
-speed sensor
If the ecu reads any signals from any of those inputs... the idle will bump up.
If you are stopped, without touching the steering wheel or brakes, and have every electrical item off... the idle should be ~800-850 rpms.
Will
-engine vacuum
-speed sensor
Will
Will
Will
[Modified by BlackAckeR, 8:50 AM 11/2/2001]
Hmm..
Hmm..
1500-1800 is too high for idle. Your Idle Air Control valve may have taken a ****. If you can't adjust the rpm's with the set screw then that's definitely your problem
01IntegraSE
Nov 15, 2003 06:41 PM
