PROs and CONs on a light flywheel?????????
Pros: much better throttle response, much faster revving.
Cons: possibly stalling in vacuum (turning with power steering and brakes in neutral, etc.), overrevving becomes much easier.
It won't add HP, but it might free up some
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">Pros: much better throttle response, much faster revving.
.</TD></TR></TABLE>
yup, took the words right out of my mouth. if anything with a lightened flywheel you might get more HP to the ground.
.</TD></TR></TABLE>yup, took the words right out of my mouth. if anything with a lightened flywheel you might get more HP to the ground.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pariah »</TD></TR><TR><TD CLASS="quote">since you'll rev faster, itsn't it true you'll lose more rpms between shifts ?</TD></TR></TABLE>
what?
does someone have an answer to this?
what?
well, to me a civic drops rpms fairly quick between shifts. granted my car is new to me and is stock, so no short shifter. buy my 95 mustang gt barely lost any momentum between shifts and it had a yardstick as a shifter
lol, I dont shift like a granny.........
i'm going to put a SI tranny in my car, so might as well put a lighter flywheel, and a new clutch.
Also for my D16 CRX, i'm also thinking about putting a lighter flywheel on that bitch.
Just need some info here. and nobody has it
I had the ACT streetlite in my HB with a B18b and that flywheel is 12.5 ish lbs. I noticed faster revs, losing rpm when shifting wasn't somthing that i noticed. If i could do it again i would try the prolite flywheel which is lighter. People that rode in the car commented on how fast it revved.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Twilight2ner »</TD></TR><TR><TD CLASS="quote">I'm new to Hondas myself, but on my Focus, I lost a full second off my 1/4 mi time with a lighter flywheel.
more details.. is it that it is harder for you to shift correctly?
</TD></TR></TABLE>more details.. is it that it is harder for you to shift correctly?
i had a comptech 8lbs flywheel, ACT MAXX pressure plate and clutchnet sprung 6 puck and i never had any problems what-so-ever launching. i actually launched a whole lot better than i did with a stock flywheel. the trick is feathering the clutch...you just have to get used to it. and to take full advantage of a lighter flywheel, try getting a short shifter. it really helps with the dropping revvs
Lightened flywheels WILL NOT show an increase in HP period. Not on a dyno, not anywhere.
They free up rotational mass allowing quicker rev matching, easier heel/toe and just better all around drivability.
There are a lot of rumors about lightweight flywheels. Personally between a lightweight flywheel, an improved final drive and a single drive crank pulley there are few and far mods that are as noticeable as these.
If you are into "street racin'" and dragging you may or may not like it. As you will probably not notice much of an increase in straight line acceleration. Once you are on a track it is a WORLD of difference. At least for me anyways.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Twilight2ner »</TD></TR><TR><TD CLASS="quote">I guess it varies from car to car.
and driver to driver.
</TD></TR></TABLE>and driver to driver.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Twilight2ner »</TD></TR><TR><TD CLASS="quote">I won't take that as an insult.
It happens on every Focus. I know this to be a fact.</TD></TR></TABLE>
oh sorry, it wasn't meant as an insult...just trying to compare that driving styles vary as well.
It happens on every Focus. I know this to be a fact.</TD></TR></TABLE>oh sorry, it wasn't meant as an insult...just trying to compare that driving styles vary as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano »</TD></TR><TR><TD CLASS="quote">Lightened flywheels WILL NOT show an increase in HP period. Not on a dyno, not anywhere.
Actually, it depends on the dyno. On a steady-state dyno, there will be no difference. But, on an inertia dyno, it can show an increase in HP numbers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRswapandslow. »</TD></TR><TR><TD CLASS="quote">all pro's, no cons
I can't agree 100%. While most of us would want at least a slightly-lightened flywheel, it isn't better for all driving conditions - especially if it gets really light.
Just as Twilight2ner said, the lighter it gets, the worse launches are. This is because when the flywheel gets spinning, it's holding all the inertia used to get the wheels spinning. When there is less weight behind it, then you need higher revs and better throttle control - especially if you have more traction (slicks) or heavy wheels.
From a physics standpoint, if you had a million-pound flywheel (and enough power to get it spinning), you could get to the end of the track just from launching and never touching the gas again (I'm sure it would even take you farther than that).
Also, with a lightened flywheel, you will notice a loss of momentum going up hills and less engine braking.
So, for dragging, it isn't necessarily what you want. For road racing, you probably want it lightened. For the street/track, you don't want it as light due to poor launchability.
