compression - anyone know what this will yield..
Old Nov 1, 2001 | 09:17 AM
Civic DX 4dr's Avatar
Default compression - anyone know what this will yield..
ok.. the motor is a 1998 Ls b18b.. we were planning on dropping in some ctr pistons but couldnt figure out what cr this would yield.. i tried asking around.. so far noone knows because hardly anyone has done this i suppose.. currently we're running a set of crower 403's with dual valve springs and titanium retainers.. but we plan on moving up to either the 404's or 405a's .. if anyone can help me with this .. i'd appreciate it.. any other suggestions would be kool also.. thanks..
Old Nov 1, 2001 | 10:57 AM
BoM's Avatar
BoM
Default Re: compression - anyone know what this will yield.. (Civic DX 4dr)
ur Compression won't be in the 11's i know that. get JE's or Endyns with ur choice of CR.
with any kind of aggressive cam u want over 11points
Old Nov 1, 2001 | 12:34 PM
Screamer's Avatar
Well on a GSR this setup yields about 11.6:1 cr. so in your case I would thik that it would be in the 11.X:1 range as well, but I am not sure. Hope this helps.
Old Nov 1, 2001 | 02:44 PM
thanks for the replies.. i really have no idea.. so any guess would be as good as mine..
Old Nov 1, 2001 | 03:09 PM
BluePrintmfg.com's Avatar
Banned
The CTR pistons should be finr in the b18b block we have that in a all motor street car and it runs very strong, yo might have to retard the timing alittle or get a thicker head gasket, but that would drop the compression. You should be fine with that set-up. GOOD LUCK!
Old Nov 1, 2001 | 07:24 PM
OneThirtyEight's Avatar
Default Re: compression - anyone know what this will yield.. (11sec.ALL MOTOR)
What kind of compression does ITR pistons in LS with a slightly resurfaced head net?
Old Nov 1, 2001 | 07:36 PM
Default Re: compression - anyone know what this will yield.. (97blackteg)
thanks for the info.. you wouldnt happen to know the CR for that motor that you mentioned would you?.. see we were thinking of milling the head a bit if the CR wasnt atleast 11.0.1 ..
Old Nov 2, 2001 | 11:00 AM
anyone else wants to take an educated guess at it??
Old Nov 2, 2001 | 02:31 PM
egghead's Avatar
I get around 11.5. On a b18c1 the compression would be about 12.
Old Nov 4, 2001 | 11:55 AM
RJL's Avatar
RJL
New User
Default Re: compression - anyone know what this will yield.. (egghead)
CTRs in a GSR block and head yield about 12:5:1 compression
wushubrian
25
Aug 31, 2006 01:52 PM
wushubrian
Aug 20, 2006 07:37 PM
Silt
Jan 12, 2004 02:17 PM
ladybug_legend
Mar 27, 2003 07:04 PM
onlyna
Mar 10, 2003 05:54 PM
