air fuel ratio fux0r
i was driving around with my wide band today.
i have a b16a1 with intake manifold and intake. 2.5 inch exhaust fuel rail, fuel pressure reg. i turned down the fuel psi like 5 psi cause it said i was running rich. but when i go full throttle my ratio is between 10.8 and 11.5 why am i running so rich up hi. i can turn the fuel down more but its already below stock settings???????????????????????????????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mustbenu »</TD></TR><TR><TD CLASS="quote">i was driving around with my wide band today.
i have a b16a1 with intake manifold and intake. 2.5 inch exhaust fuel rail, fuel pressure reg. i turned down the fuel psi like 5 psi cause it said i was running rich. but when i go full throttle my ratio is between 10.8 and 11.5 why am i running so rich up hi. i can turn the fuel down more but its already below stock settings???????????????????????????????</TD></TR></TABLE>
You want to keep fuel psi around 40psi at idle, sounds like you need a VAFC and some serious tuning.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mustbenu »</TD></TR><TR><TD CLASS="quote">if u read the first line of my post it says i have a wide band </TD></TR></TABLE>
Right, so Get an AFC and do some tuning!
