Passing State Inspection with JDM Engine
The car has a JDM B18C in it. I have a Carsound Cat installed, so emissions shouldn't be a problem. My worry is with the visual inspection. Will I be able to pass without an EGR and other components not found on the JDM engine? BTW, I'm in PA so any of you guys within the state, help from you is especially appreciated.
try http://www.Pa-hondas.org it might just take a couple hours to get an answer cause its a little slow, but you will get an answer. I really dont know much about it or i would help. good luck
