need advice on how to install a slave cylinder
Old Apr 27, 2004 | 01:16 PM
90babyblue's Avatar
Default need advice on how to install a slave cylinder
hi you doin i was wondering if someone could give me advice on how to install a slave cylinder on my 90 accord ex. i wold greatly appreciate it. thanx guys.
Old Apr 27, 2004 | 04:46 PM
SearchBeforeUPost!'s Avatar
Default Re: need advice on how to install a slave cylinder (nubehonda)
1. crack beer
2. remove clutch fluid line
3. remove 2 10mm bolts holding slave cyl on tranny
4. install new slave cyl with 10mm bolts
5. reinstall fluid line
6. crack other beer
7. bleed clutch
Old Apr 27, 2004 | 06:53 PM
tommymoose's Avatar
Default Re: need advice on how to install a slave cylinder (SearchBeforeUPost!)
I actually have to do the same thing. I have been putting it off and my problem is getting increasingly worse. I am waiting for my Haynes manual to come in the mail(ordered a week ago) so that I could use that to guide me, but if its that easy I'll follow your advice. Would the process be the same for a 96 Accord LX?
Old Apr 28, 2004 | 09:04 AM
90babyblue's Avatar
i know this might sound stupid but when i bleed the clutch how do i do this. haha i have messed around with engines but never with a honda tranny. haha first time for everything right. lol where is the input for the dot3 fluid???? thanks guys you are very helpful
Old Apr 28, 2004 | 09:51 AM
Beach Accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nubehonda &raquo;</TD></TR><TR><TD CLASS="quote">i know this might sound stupid but when i bleed the clutch how do i do this. haha i have messed around with engines but never with a honda tranny. haha first time for everything right. lol where is the input for the dot3 fluid???? thanks guys you are very helpful</TD></TR></TABLE>
the fluid reservoir should be at the back right of your firewall. pour fresh fluid in, have someone pump clutch 4 times and hold it, open bleeder screw, close bleeder screw. pump 4 times hold, open bleed screw, close bled screw, keep adding fresh fluid until fresh fluid starts comin out of bleeder screw.
Old Apr 28, 2004 | 10:03 AM
aznballerz's Avatar
Default Re: need advice on how to install a slave cylinder (Beach Accord)
what if you trace the line but there's no leakage...but the clutch fluid keeps emptying out? Is there something wrong with the inside of the clutch or something? Would it be easier to just replace the clutch?
Old Apr 28, 2004 | 10:54 AM
Default Re: need advice on how to install a slave cylinder (aznballerz)
replacing the clutch has nothing to do with the fluid level, or loss of fluid. Sounds like you need to bleed the system further.
This process is the same for all hondas with hydro trannies.
Old Apr 28, 2004 | 11:17 AM
tommymoose's Avatar
About how much DOT 3 oil will I need?
Old Apr 28, 2004 | 03:03 PM
aznballerz's Avatar
what do you mean by bleeding it further because everytime i bleed it...it goes back to normal and about 2 months later, it would be empty again...so there must be some leakage around somewhere...that's my problem...
Old Apr 29, 2004 | 08:37 AM
check for leaks above the pedal inside the car.
Nickhead
May 20, 2011 03:20 PM
PinoyDelS0l
Jun 23, 2008 09:36 PM
Brycen
Apr 15, 2005 04:34 PM
90babyblue
Apr 29, 2004 09:07 AM
revhigh89
Feb 15, 2004 03:10 PM
