CRX w/ B16 Does it matter what clutch to use???
Old Apr 27, 2004 | 12:45 PM
nitrousjunkieCRX's Avatar
Default CRX w/ B16 Does it matter what clutch to use???
I need to get a clutch for my crx's B16. what application do i use when i order one? 94-97 del sol Vtec B16??? does it matter that it is a cable trans VS. a hydro?
Old Apr 27, 2004 | 01:52 PM
B2FiNiTY's Avatar
Default Re: CRX w/ B16 Does it matter what clutch to use??? (nitrousjunkieCRX)
yes it does mater. for cable trannies use 90-93 integra clutches.
Old Apr 27, 2004 | 03:26 PM
EL Vap133's Avatar
Default Re: CRX w/ B16 Does it matter what clutch to use??? (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">yes it does mater. for cable trannies use 90-93 integra clutches. </TD></TR></TABLE>
Exactly.
Old Apr 27, 2004 | 10:47 PM
SiR Kid's Avatar
New User
Default Re: CRX w/ B16 Does it matter what clutch to use??? (EL Vap133)
Exactly WRONG.
89-91 B series trannies had a smaller input shaft diameter on the transmission than the 92-01 models, which makes the clutch disk spline diameter smaller for these years.
92-01 B series trannies are all the same, however, hydraulic or not.
Do you have an 89-91 Tranny, or a 92-01 tranny?
Old Apr 28, 2004 | 01:56 PM
Default Re: CRX w/ B16 Does it matter what clutch to use??? (SiR Kid)
i have a YS1 trans which is a 89-91.
Old Apr 28, 2004 | 02:08 PM
krazie1's Avatar
BANNED
no u have to use 90-93 teg clutches
and WTF!!!!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Kid &raquo;</TD></TR><TR><TD CLASS="quote">Exactly WRONG.
Do you have an 89-91 Tranny, or a 92-01 tranny?</TD></TR></TABLE>
just get a 90-93 and u set that is what most of us "normal" peeps got in here
Old Apr 28, 2004 | 02:18 PM
EL Vap133's Avatar
Default Re: CRX w/ B16 Does it matter what clutch to use??? (krazie1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazie1 &raquo;</TD></TR><TR><TD CLASS="quote">no u have to use 90-93 teg clutches
and WTF!!!!!!!!!
just get a 90-93 and u set that is what most of us "normal" peeps got in here</TD></TR></TABLE>
hahahaha, you tell him brutha!
Old Apr 28, 2004 | 02:23 PM
Malgerus's Avatar
92+ ARE different. Larger shaft.
Old Apr 28, 2004 | 09:59 PM
SiR Kid's Avatar
New User
and WTF!!!!!!!!!
Go ahead, keep telling him the WRONG INFO.
I hope you waste $300 on an incorrect clutch, install it, it spins on the input shaft, and you are out the time of a clutch install, AND $300, because of people mocking people who know what they are talking about.
Fellow Honda-techians, the ignorant ******** here can suck mah nurtz.
Read and learn...
Old Apr 28, 2004 | 10:01 PM
SiR Kid's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
hahahaha, you tell him brutha! </TD></TR></TABLE>
Apparently you are the blind led by the blind.
STFU and learn something from the people that know better because they've been there, done that.
******* dumbass.
Old Apr 28, 2004 | 10:08 PM
SC0TT's Avatar
HAHAHA guys.....
There are two different spline lenths between 90-93.
90-91 Integra cable= Most JDM swaps come with this size(J1,s1,y1), im not sure what lenths, but order the clutch in these years.
92-93 Integra cable- Rarely find a JDM swap with the spline equal to these.
*recommend exedy organic*
Old Apr 28, 2004 | 10:47 PM
crx2fast's Avatar
Default Re: (SC0TT)
dude any b-serious tranny will bolt up. as for cable or hydraulic thats up to you. yea and you need a clutch from a teg 90-93
Old Apr 29, 2004 | 01:31 AM
SiR Kid's Avatar
New User
Default Re: (crx2fast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx2fast &raquo;</TD></TR><TR><TD CLASS="quote">dude any b-serious tranny will bolt up. as for cable or hydraulic thats up to you. yea and you need a clutch from a teg 90-93 </TD></TR></TABLE>
Quit spreading misinformation.
90-93 Integra clutches are NOT the same.
Old Apr 29, 2004 | 02:01 AM
Boosted Chemist's Avatar
Default Re: (SiR Kid)
90-93 Integra clutches are NOT the same.</TD></TR></TABLE>
He is right 92-93 are different than 90-91, but i had a ys1 (ls 92-93) in my crx on the same clutch i had my y1 on so i belive they are interchangable (go figure ), just take the clutch disk and throw it on the input shaft and make sure it goes on and you should be kosher, i believe alll b series take the same pressure plate.
Old Apr 29, 2004 | 03:04 AM
1st-hybrid's Avatar
Good to see someone who knows what they're talking about still on this board .
They are not the same, if you don't believe him call somewhere and order one for a 90-93 integra and they will, if they're reputable, ask you about the exact year and spline size.
I got mine here: http://www.clutchcityonline.com/acura_integra.htm
I can't remember if I got this or the race, I'd have to check. But either way they were great to do business with and the first thing they asked was what year tranny and about the spline size.
Old Apr 29, 2004 | 03:56 AM
crx2fast's Avatar
my bad guys. i ment 90-91. the 92 are i think for like 1.8's but dont quote me on that. its funny cause i just changed my clutch.
Old Apr 29, 2004 | 05:08 AM
joesefcivic's Avatar
90-91 that is what i used. good luck.
axionm1k
Apr 14, 2008 04:40 PM
axionm1k
Apr 14, 2008 03:36 PM
ef-b16sedan
Jan 14, 2008 07:31 AM
da_rimrocka
May 16, 2006 04:09 PM
Hybrid Invasion
Jan 26, 2004 04:09 PM
