Liquid Metal??? Anyone with experience?
Naw it a hardening substance, that is suppose to be better to fix inperfections on your body , better than any bondo, or fiberglass. Check it out, http://www.liquidmetal.com
oh ok I saw that before under a different name. It's good for areas that need welding. like a rust hole. it hardens like metal and good for areas that would normally require welding but can't. It is not good for regular dents as it dries with more pinholes than bondo. I work at a body shop btw
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
name? aside from liquid metal, i would prefer the commersial name.
I got a door hinge that is popping and it needs welding, this will save me from stripping half of the car to do so.
stan
stan
