Can i use a automatic wiring harness on a 5spd?
Old Apr 27, 2004 | 10:54 AM
trooper0641's Avatar
Default Can i use a automatic wiring harness on a 5spd?
Will it work? Should i be aware of anything? This is going to be in my 92 cx w/ a d15b motor with a p28.
Old Apr 27, 2004 | 11:09 AM
Default Re: Can i use a automatic wiring harness on a 5spd? (trooper0641)
ttt
Old Apr 27, 2004 | 11:18 AM
dantastic's Avatar
my 5-sp b series swap came with an auto harness. the only thing that didnt plug in was the reverse switch on the tranny. hth if at all
Old Apr 27, 2004 | 11:27 AM
Donkey85's Avatar
Default Re: (dantastic)
it should work but you may have to steal a few plugs off of the old stock one and piece it together to make it work properly
Old Apr 27, 2004 | 11:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">my 5-sp b series swap came with an auto harness. the only thing that didnt plug in was the reverse switch on the tranny. hth if at all</TD></TR></TABLE>\
hmmm...thats what i heard...the auto comes in with a extra plug or so. Did you have any problems?
Old Apr 27, 2004 | 01:34 PM
Default Re: (trooper0641)
23rwefdsf
Old Apr 27, 2004 | 01:43 PM
Street Ghost's Avatar
It should work, I did an auto-to-manual conversion on my Civic running the stock harness.
Old Apr 27, 2004 | 02:14 PM
Default Re: (JDM Ninja)
nice...i think ill just go get that auto z6 harness and plug & play the d15b into my 92 cx
Old Apr 27, 2004 | 02:20 PM
Dyzee's Avatar
I did a D16Z6 swap into my (used to be) automatic DX. There were NO extra plugs as per common mistake,.
Everything plugged in fine with no extra things attached.
Old Apr 27, 2004 | 02:23 PM
Default Re: (Dyzee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dyzee &raquo;</TD></TR><TR><TD CLASS="quote">I did a D16Z6 swap into my (used to be) automatic DX. There were NO extra plugs as per common mistake,.
Everything plugged in fine with no extra things attached.</TD></TR></TABLE>
o? and im assuming you used your stock "auto" dx harness?
Old Apr 27, 2004 | 10:00 PM
yergs
Old Apr 28, 2004 | 06:26 AM
23rwed
Old Apr 28, 2004 | 07:54 AM
92-95 automatic d16z6 wiring harness = be ok = for swapping in a 5spd motor?
NatedoggAZ
13
Nov 26, 2003 10:20 PM
jumpmann23
Aug 18, 2003 09:35 PM
